Passing a polyline entity to extrim
SORONW
SORONW
(setq cl (Polyline (list (list (car ap) (cadr ap) 0) (list (car ap) (+ (cadr ap) pr7) 0) (list (+ (car ap) pr6) (+ (cadr ap) pr7) 0) (list (+ (car ap) pr6) (cadr ap) 0))))
(trim cl (list (+ (car ap) (/ pr6 2)) (- (cadr ap) (/ pr7 2)) 0))
(defun TRIM ( et pt /)
	(if
		(cond
			(etrim)
		(T (load "extrim.lsp" "") etrim)
		(etrim et pt)
	(setvar "highlight" 1)
(defun Polyline (lst)
 (entmakex (list (cons 0 "POLYLINE")
                 (cons 10 '(0 0 0))))
 (mapcar
   (function (lambda (p)
               (entmake (list (cons 0 "VERTEX") (cons 10 (trans p 1 0)))))) lst)
 (entmakex (list (cons 0 "SEQEND"))))
I've got the above bit of code, using some functions found here https://www.cadtutor.net/forum/topic/18257-entmake-functions/#comments The goal is to draw an open polyline (in this case, a rectangle missing a side), then pass that polyline to the trim function to trim all lines on one side. The shape gets drawn as expected, and no error message appears but the lines will remain untrimmed.  I've been able to make a similar situation with regular lines work correctly, but it doesn't seem to like polylines. My best guess is that something with passing the entity name is wrong, but I haven't yet figured out what.
Anyone have any suggestions? Thanks.
EDIT: Its also worth mentioning that using the extrim command outside of the lisp routine functions as expected in this situation.
devitg
Please upload your sample.dwg
SORONW
Heres the sample. The shapes in question are the two squares in the middle of the upper view.
devitg
The fact is that EXTRIM "cut all" inside or outside the poly so the green and the yellow  lines
Sea-Haven
Ok try this
remove (setq cl and last bracket )
change (trim (entlast) (getvar 'extmax)) if want all
(trim (entlast) pt)
Had to guess ap pr6 pr7 add to code as dummys next time.
SORONW
Thank you Sea.haven, your suggestion got me closer to a solution. When generating a part, the bottom notch trims as expected, but the top notch only trims the outer solid line. The hidden dashed line remains untrimmed. Whats interesting is that If I change the layer of the dashed line to the obj layer, the trim works as expected. This can be replicated outside of my code using extrim, so I suspect its an issue on that end. I will start a seperate topic for that investigation though.
