pass symbols to mapcar
TanguyNed
Message 1 of 14
TanguyNed
Sorry if that's a dumb question, I'm only a casual developer.
This code below returns a syntax error when I try to execute it. I fail to understand why. The problem is with the (apply 'setq x) part.
(mapcar '(lambda (x)  (OR (eval (car x)) (apply 'setq x)))
	'((*param1* 1.00)
	  (*param2* "Active")
	  (*param3* 0.02))
Any help appreciated.
Replies (13)
Message 2 of 14
_gile
(mapcar '(lambda (sym val)
	    (or (eval sym) (set sym val))
	 '(*param1* *param2* *param3*)
	 '(1.00 "Active" 0.02)
Gilles Chanteau
GileCAD
GitHub
Message 3 of 14
_gile
Maybe (boundp sym) is more self explanatory than (eval sym)
	    (or (boundp sym) (set sym val))
Gilles Chanteau
GileCAD
GitHub
Message 4 of 14
_gile
With a single list of lists as in your first post, you have to use (apply  'set x) instead of (apply 'setq x) because (car x) is already quoted (due to the fact it's an item of a quoted list).
(mapcar	'(lambda (x) (or (eval (car x)) (apply 'set x)))
	'((*param1* 1.00)
	  (*param2* "Active")
	  (*param3* 0.02)
Gilles Chanteau
GileCAD
GitHub
Message 5 of 14
ronjonp
A few more:
(mapcar	'(lambda (x) (set (car x) (cadr x)))
	'((*param1* 1.00) (*param2* "Active") (*param3* 0.02))
(foreach i '((*param1* 1.00) (*param2* "Active") (*param3* 0.02))(set (car i) (cadr i)))
(defun _set (x) (set (car x) (cadr x)))
(mapcar	'_set
And if you don't need to set variables, you could use an association list and pull the values using a key:
(cadr (assoc "*param2*" '(("*param1*" 1.00) ("*param2*" "Active") ("*param3*" 0.02))))
Message 6 of 14
Kent1Cooper
@ronjonp wrote:
A couple more: ....
Those look like they will just set those values into those variables, regardless.  @TanguyNed, am I correct that you want each one set only if there is not already a value in that variable?
Kent Cooper, AIA
Message 7 of 14
TanguyNed
@Kent1Cooper Yes that is correct.
@_gile I didn't know the existence of the (set) function, that was my only problem.  I didn't know about (boundp) either.
Thanks to all for the very quick answers.
Message 8 of 14
ronjonp
@Kent1Cooper wrote:
@ronjonp wrote:
A couple more: ....
This is correct. Maybe the OP can clarify.
Here's a simple mod ( which can be applied to all ) to the last example that checks for a nil value:
(defun _set (x) (and (null (car x)) (set (car x) (cadr x))))
(mapcar '_set '((*param1* 1.00) (*param2* "Active") (*param3* 0.02)))
*Edit .. which I guess as a literally quoted list won't work so you'd have to stick with eval.
Message 9 of 14
_gile
(setq a 42) stands for: (set (quote a) 42) or (set 'a 42)
Gilles Chanteau
GileCAD
GitHub
Message 10 of 14
TanguyNed
This does make sense, the "q" means "quote"!  The functions' names are often an abbreviation of something, I've been using them without really understanding what they mean. There are other examples (atof??? or even car/cdr?). Guess that's what happens when you have no formal prior knowledge about coding.
Message 11 of 14
_gile
atof si quite simple: alphabetic to float.
car and cdr, which are fundamental functions of all LISP languages, are more obscure. They are the acronyms of, respectively, 'contents of the address part of register' and 'contents of the decrement part of register' which are related to the basic structure of LISP lists: the cons cell whose name comes from the cons function, another fundamental function of LISP languages.
Gilles Chanteau
GileCAD
GitHub
Message 12 of 14
Sea-Haven
Another method is as you can have as many variables as you want that match the number of items in a list. Its a more global approach for any code where you want common variable names.
(setq lst '(1.00  "Active" 0.02))
(setq num 0)
(mapcar '(lambda (x) (set (read (eval (strcat "*param" (rtos (setq num (1+ num)) 2 0) "*"))) x)) lst)
 Convert a list to a sequence of variable names (theswamp.org)
Message 13 of 14
martti.halminen
The historical origin of car and cdr is as assembly language commands XCARF and XCDRF on an IBM 704.
For anybody interested in ancient history, these may be interesting:
https://dl.acm.org/doi/pdf/10.1145/800055.802047
https://dl.acm.org/doi/pdf/10.1145/321021.321022
https://en.wikipedia.org/wiki/IBM_704
- Though they may be a little heavy reading; the early Lisp literature is not famous for its readability.
Message 14 of 14
TanguyNed
Thank you all again, my needs are simple but this is all very educational. I will make sure to read the links that were mentioned.
