Pass in selection to ATTEDIT
AGGilliam
AGGilliam
Long story short, we have nested blocks and I would like to create a selection set from the child blocks that contain our attributes and pass it into ATTEDIT. The part where I'm stuck, is that P doesn't sem to work within ATTEDIT to use the previous selection set. I tried manually selecting the attributes before running the command as well as using ssget to select everything before the command but it always says 0 found unless I manually select the attributes during the command instead of entering P. This was within the command prompt if that makes a difference?
This is the ATTEDIT command, the attribute values are all correct and works just fine if I replace the P with a manual selection
(COMMAND "-ATTEDIT" "N" "Y" "ATT" "ITEM" "*" "P" "760300" "W")
This is the ssget command I used, which contained 1243 entities
(SETQ ATTSSS (SSGET "X" (LIST (CONS -4 "<AND") (CONS 0 "INSERT") (CONS 2 "ATT*") (CONS -4 "AND>"))))
Am I missing something or is this just not an available functionality?
Jonathan3891
I think if you convert your sset into a list you could iterate through it using attedit in command line.
Jonathan Norton
Blog | Linkedin
paullimapa
komondormrex
so you want to change attribute tagged "ITEM" in a bunch of blocks named "ATT*" from value "760300" to value "W"?
AGGilliam
That was just a test, but yes that's basically the idea. They're also nested within another block, we'll call it the door block, that contains a bunch of other attribute blocks. I want the user to select the door blocks where they want to edit the attribute. My initial thought was to loop through the door blocks and create a selection set of the attribute blocks I wanted but I wasn't sure where to go from there since selecting the previous selection set doesn't work within ATTEDIT. I haven't had the chance to try anyone else's ideas yet.
komondormrex
i think using 'attedit to work out your wanting is a dead end. and like it was already mentioned it needs to be solved using blocks' lists, attributes' lists, dcl...
komondormrex
on the other hand you may select blocks needed like this
(sssetfirst nil (ssget "_x" (list '(0 . "insert") '(2 . "att*"))))
and change common attributes in the properties tab.
