Partial loaded cuix files not displaying correctly
gccdaemon
gccdaemon
I posted this in another section and got zero responses, so I'm trying here to see if someone knows what's going on.
I have the company's CUIX file partial loaded...
The tollbar and menu files are added to the workspace as well...
The problem is that neither the drop down menu or the toolbar show. When I check the menuload the CUIX doesn't show as loaded.
Now, if I load the cuix with menuload, everything shows correctly. I have saved the workspace and profile and exported the profile ARG and no matter what I do, after I close CAD and reopen, the toolbars and menu disappear again. Is there a glitch I'm unaware of?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
dgorsman
Is this Map3D?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
gccdaemon
Civil3D 2015.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
pendean
Community Legend
Community Legend
Do you have read/write/edit/delete access to the folder that contains your CUIx file that contains your custom workspace?
Who set up your C3D station? It's curious how your screenshots are out of order, the partial shown as installed with the CUILOAD shows it as not.
gccdaemon
I have full read/write permissions. I set up my own station and am essentially the CAD Manager. Boggles me too. I just checked again and it doesn't appear to be saving any changes to my workspace even after deleting it and creating another. It was working fine for a long time, but mybe something got corrupted on crash at some point?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
gccdaemon
Found a thread that helped in a swamp post. Here is how I solved it. (must be in order)
1. Browse to the "AppData\Roaming\Autodesk\C3D 2015\enu\" folder, right click on the support folder and select properties. Then check and uncheck the read-only for all subfolders and files.
2. Save the workspace.
3. Remove and re-add the support paths. Apply changes. (Export your arg if you use a modified link)
4. Unload and reload the "Trouble" menu.
5. Save the workspace again.
Don't know why, but it worked.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
