parent/child blocks
parent/child blocks
razie.electric
parent/child blocks
razie.electric
dears,
I am looking for autolisp codes to help me as I describe here:
I have a block as a parent and other blocks as child, I am looking for codes that when I use child blocks it automatically give me parent address (like k200 and k100 in the pdf I have attached).
Moshe-A
@h@razie.electric hi,
from your pdf we can not tell what is k200 and what is k100?
so let assume this:
k100 is parent block
    k200 is the child
you could define such a function to insert a family block
(defun insert-family-block (blkname ins)
 (if (wcmatch (strcase blkname) "K100,K200,K300,K400")
  (progn
   ; your code
   (command "._insert" "k100" ins 1 1 0)
   ; your code
usage:
(insert-family-block "block-name" ins-point)
the parent block will be insert even if a child block is specified
moshe
razie.electric
I THINK THERE IS A MISUNDRESTANDING
I ATTACHED THE FILE AGAIN
Moshe-A
@razie.electric,
explain what do you mean by "when i use child block it automatically give give me parent address"?
when i use means: insert?
parent address means: coordinates? block name?
razie.electric
YES exactly when I insert the block child it should shows the adress of block parent just like how the attached file shows
the address is the page name which has been shown in the corner of page( right-down)(8302 is the address of sheet ) and as you see the address of k200(child block) is 8302.5 (.5 shows the number of sheet's row)
