Parallel xline
Parallel xline
Browning_Zed
Message 1 of 8
Parallel xline
Browning_Zed
Hi!
Here on the forum I found a lisp code that creates an xline perpendicular to the selected entity (line, polyline, circle, etc.). The code works as it should, but I would like to change it so that a parallel is created instead of the perpendicular. How to do it?
(defun c:perxl ( / *error* acadobj adoc crv msp perpt pt)
  (defun *error* ( msg )
    (vla-EndUndoMark adoc)
    (if (not (wcmatch (strcase msg T) "*break*,*cancel*,*exit*"))
      (princ (strcat "Error: " msg))
  (setq acadobj (vlax-get-acad-object)
	adoc (vla-get-ActiveDocument acadobj)
	msp (vla-get-ModelSpace adoc)
  (vla-StartUndoMark adoc)
  (while
    (progn
      (setq crv (entsel "\nSelect curve: "))
      (cond
	((null crv) (princ "\nNothing selected"))
	((null (wcmatch (cdr (assoc 0 (entget (car crv)))) "LINE,*POLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE"))
	 (princ "\nObject is not a curve")
  (initget 1)
  (setq pt (getpoint "\nSpecify point: ")
	perpt (vlax-curve-getclosestpointto (car crv) pt)
  (vla-AddXline msp (apply 'vlax-3d-point pt) (apply 'vlax-3d-point perpt))
Accepted solutions (3)
Replies (7)
Message 2 of 8
ВeekeeCZ
IMHO this looks you're rather inefficient working with your osnaps or must do this kind of job like a thousand times a day. Because it's all about osnaps.
Anyway, this following version of PerXl gives me much more sense (for ACAD 2016+).
HTH
(defun c:PerXl nil
  (command-s "_.xline" "_per")
  (princ)
(defun c:TanXl nil
  (command "_.xline" pause "_tan" pause "")
  (princ)
Edit: Did you really meant "a parallel" rather than "tangent"?
Message 3 of 8
marko_ribar
Based on your posted code...
(defun c:parxl ( / *error* acadobj adoc crv msp perpt pt fd )
  (while
    (progn
      (cond
        ((null crv) (princ "\nNothing selected..."))
        ((null (wcmatch (cdr (assoc 0 (entget (car crv)))) "LINE,*POLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE,HELIX"))
         (princ "\nObject is not a curve...")
  (initget 1)
        fd (vlax-curve-getfirstderiv (car crv) (vlax-curve-getparamatpoint (car crv) perpt))
  (vla-AddXline msp (apply 'vlax-3d-point pt) (apply 'vlax-3d-point (mapcar '+ pt fd)))
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 8
ВeekeeCZ
Little different approach.
(defun c:parxl ( / *error* acadobj adoc crv msp parpt pt fd )
  (while (progn
	   (cond ((null crv)
		  (princ "\nObject is not a curve")))))
  (while (setq pt (getpoint "\nSpecify point: "))
    (setq parpt (vlax-curve-getclosestpointto (car crv) (cadr crv))
	  fd (vlax-curve-getfirstderiv (car crv) (vlax-curve-getparamatpoint (car crv) parpt)))
    (vla-AddXline msp (apply 'vlax-3d-point pt) (apply 'vlax-3d-point (mapcar '+ pt fd))))
  (princ)
Message 5 of 8
marko_ribar
Actually, in both codes, it should be :
(setq pt (trans (getpoint "\nSpecify point: ") 1 0))
30 min. rule beat me to mod. my code...
Message 6 of 8
ВeekeeCZ
Good point Marco!
Although, in my case has to be more than that.
(vl-load-com)
(defun c:parxl ( / *error* acadobj adoc crv msp pt fd )
  (while (progn
	   (cond ((null crv)
    (setq fd (vlax-curve-getfirstderiv (car crv)
		 (vlax-curve-getclosestpointto (car crv) (trans (cadr crv) 1 0))))
	  pt (trans pt 0 1))
  (princ)
Message 7 of 8
Kent1Cooper
Since I had it going before other similar posts, here's another slightly different way, using the first derivative but with (polar) and (angle) functions:
(defun c:parxl (/ *error* acadobj adoc msp crvsel crv perpt pt)
  (setq
  (while
    (progn
      (setq crvsel (entsel "\nSelect curve: "))
      (cond
        ((null crvsel) (princ "\nNothing selected"))
        ((null (wcmatch (cdr (assoc 0 (entget (setq crv (car crvsel))))) "LINE,*POLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE,XLINE,RAY"))
  (initget 1)
  (setq
    perpt (vlax-curve-getclosestpointto crv pt)
  (vla-AddXline msp
      (polar
        pt
        (angle '(0 0) (vlax-curve-getFirstDeriv crv (vlax-curve-getParamAtPoint crv perpt)))
        1
  (princ)
I added XLINE and RAY to the possible objects to draw parallel to.  But not HELIX, because (polar) and (angle) don't do off-the-current-drawing-plane for a Helix that's not flat.  And I didn't deal with a possible different UCS, but that could be worked in if needed.
Kent Cooper, AIA
Message 8 of 8
Browning_Zed
Thank you, guys! All codes work fine.
