Paper space and Model space layout
Code_x
Message 1 of 12
Code_x
Hi, I'm using AutoCAD 2024 and was wondering if there are any shortcuts or commands that would allow me to switch between paper space layout and model space layout using a combination of shortcut.  Please advise.
Replies (11)
Message 2 of 12
komondormrex
hey,
eg. you may add shortcuts to the commands pspace and mspace via customization.
Message 3 of 12
Kent1Cooper
Is the MODEL/PAPER toggle button in the Status Bar not a short-enough cut?
Kent Cooper, AIA
Message 4 of 12
pendean
Community Legend
Community Legend
Are you aware of VPMAX and VPMIN commands @Code_x
Or do you just need the functions of PSPSACE and MSPACE commands?
OR... TILEMODE=1 and TILEMODE=0?
Your post is unclear on your exact need.
Once you decide... all you need to do is start CUI command and
Message 5 of 12
Code_x
When I'm in the paper space and typing 'Mspace,' it takes me to the viewport on the sheet, but not to the actual model space. I wonder why?
Message 6 of 12
ec-cad
If you are in a Layout tab, with a Viewport active, that's what happens.
Try just picking the "Model" tab (lower Left of screen) instead if you want to see the Model space.
ECCAD
Message 7 of 12
Code_x
I discovered the solution to my own question: Ctrl+PageDown or Ctrl+PageUp switches between the model tab and the layout tab.
Message 8 of 12
ec-cad
That's 2 key clicks, vs 1 mouse click, but if it feels good - do it.
ECCAD
Message 9 of 12
pendean
Community Legend
Community Legend
That's not 'switching', that's cycling: great only if you have the one and only layout
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cycling-through-La....
TILEMODE command set to 0 or 1 is "switching".
Message 10 of 12
Sea-Haven
This is a Goto for layouts, handy when you have lots of layouts, just enter a number for the layout starts at 1, Model is 0.
Message 11 of 12
rgrainer
Is this what you are after?
(defun c:tm ()
 (if (= (getvar "TILEMODE") 1)
   (command "tilemode" 0)
   (command "tilemode" 1)
 (princ)
Message 12 of 12
Kent1Cooper
If indeed that is what they're after, there's a shorter way to toggle something with values of only 0 & 1 to toggle between -- no checking the current value is needed:
(setvar 'tilemode (- 1 (getvar 'tilemode)))
Kent Cooper, AIA
