PageSetup Lisp
PageSetup Lisp
francine.zimmermannSRSWJ
Message 1 of 8
PageSetup Lisp
I have a Lisp CH-A.LSP with different pagesetup command.
(defun C:CH-A0-L()
(command "_-PAGESETUP" "DWG To PDF_font_to_geometry.pc3" "ISO full bleed A0 (841.00 x 1189.00 MM)" "" "L" "N" "L" "1:1" "0.00,0.00" "Y" "KGC_PLOT_STYLE" "Y" "Y" "N" "N")
(princ)
(defun C:CH-A0-P()
(command "_-PAGESETUP" "DWG To PDF_font_to_geometry.pc3" "ISO full bleed A0 (841.00 x 1189.00 MM)" "" "P" "N" "L" "1:1" "0.00,0.00" "Y" "KGC_PLOT_STYLE" "Y" "Y" "N" "N")
(princ)
The Lisp works fine, but by using the macro in my Ribbon, the command line contains a text that I didn't call up.
I think my lisp isn't written properly.
Macro example: ^C^C(load "CH-A.lsp");CH-A2-P;
Command: (LOAD "CH-A.LSP")
C:CH-A4-P   this text is strange because I don't call it
Command: CH-A2-P _-PAGESETUP Enter an output device name or .......
Thank you in advance for your help
Replies (7)
Message 2 of 8
paullimapa
that's because it's reporting the last defun statement you have in your lisp which shows CH-A4-P:
(defun C:CH-A4-P()
 (command "_-PAGESETUP" "DWG To PDF_font_to_geometry.pc3" "ISO full bleed A4 (210.00 x 297.00 MM)" "" "P" "N" "L" "1:1" "0.00,0.00" "Y" "KGC_PLOT_STYLE" "Y" "Y" "N" "N")
(princ)
 If you don't want to see this then add this as the last line in the lisp file:
(princ)
Also this pagesetup sequence only works in Paper space. The sequence changes a bit towards the end in Model. So you may want to add the code to switche to paper space in each one of the defun statements like this one:
(defun C:CH-A4-P()
 (setvar"TILEMODE"0) ; make sure is set in paper space
(princ)
Paul Li
IT Specialist
@The Office
Message 3 of 8
I have modified the lisp in accordance with your comments but it change nothing2024-02-07 19_37_08-AutoCAD Text Window - Drawing1.dwg.png
Message 4 of 8
paullimapa
repost your changed lisp so we can see the changes you made
Paul Li
IT Specialist
@The Office
Message 5 of 8
I reposted it
Message 6 of 8
paullimapa
again this is the end of the file as you show it now:
(defun C:CH-A4-P()
(princ)
I don't see the additional princ function statement added as the last line of the entire file not just within the defun statement. So when you add this as the last line that would give you a clean load like this:
(defun C:CH-A4-P()
(princ)
(princ) ; clean load
Paul Li
IT Specialist
@The Office
Message 7 of 8
Perfect ‌‌
Thanks a lot
Message 8 of 8
paullimapa
Glad to have helped...Now you could also include a prompt letting the user know that the code loaded successfully like this:
(princ"\nCH-A.lsp Pagesetups Loaded Successfully.")
(princ) ; clean exit
Paul Li
IT Specialist
@The Office
