Overwrite PRINT function
pavel_hosek
pavel_hosek
Is it possible to overwrite the default _PRINT function (the one called by ctrl+P)? I would like to automatically check the drawing by my own LISP (for instance for layers that have been switched off accidentaly) before allowing the user to print it.
komondormrex
your custom command or function to check and then plot.
clear Ctrl-P and click OK.
paullimapa
You can try command Undefine and then enter Print
Paul Li
IT Specialist
@The Office
Kent1Cooper
@pavel_hosek wrote:
.... the default _PRINT function (the one called by ctrl+P) ....
That's actually _PLOT [unless that's changed in a newer version than 2020 that I have here -- I can check in 2024 elsewhere later] -- PRINT is just an alias.  If you want to UNDEFINE, it needs to be the actual command name [I get an unknown-command-name error message if I try to UNDEFINE PRINT or use it in an AutoLisp (command) function].  You can then define your own under the same name if you want [so it will be what is invoked by Ctrl+P], doing your own stuff before calling the real command using:
(command "_.plot" ...)
with the period prefix to force the use of the native command.  If you've Undefined it, the (command) function won't recognize it without that.
Kent Cooper, AIA
