Overlap With Trimming Lines
rpajounia
rpajounia
So i am currently using the code below and it creates a new line between overlapping lines but i also need to trim the over lapping lines too can someone help me modify it
Example:
Line one starts from 0 to 5
Line two starts from 3 to 8
Make line one 0 to 3
Makes new line 3 to 5
Make line two 5 to 8
(defun c:overlap ( / _line _online a e i l s ent ss1)
   (defun _line ( a b )
       (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b)))
   (defun _online ( p a b )
       (equal (+ (distance p a) (distance p b)) (distance a b) 1e-1)
   (if (setq s (ssget "_A" '((0 . "LINE"))))
       (progn
           (repeat (setq i (sslength s))
               (setq e (entget (ssname s (setq i (1- i))))
                     l (cons (list (cdr (assoc 10 e)) (cdr (assoc 11 e))) l)
           (while (setq a (car l))
               (foreach b (setq l (cdr l))
		   (princ l)
                   (cond
                       (   (or
                               (and
                                   (equal (car  a) (car  b) 1e-1)
                                   (equal (cadr a) (cadr b) 1e-1)
                               (and
                                   (equal (car  a) (cadr b) 1e-1)
                                   (equal (cadr a) (car  b) 1e-1)
                           (apply '_line a)
                       (   (and
                               (_online (car a) (car b) (cadr b))
                               (_online (car b) (car a) (cadr a))
                               (not (equal (car a) (car b) 1e-1))
                           (_line (car a) (car b))
                       (   (and
                               (_online (cadr b) (car a) (cadr a))
                               (not (equal (car a) (cadr b) 1e-1))
                           (_line (car a) (cadr b))
                       (   (and
                               (_online (cadr a) (car b) (cadr b))
                               (not (equal (cadr a) (car b) 1e-1))
                           (_line (cadr a) (car b))
                       (   (and
                               (not (equal (cadr a) (cadr b) 1e-1))
                           (_line (cadr a) (cadr b))
   (princ)
ВeekeeCZ
Post a drawing to illustrate what it does and what you would like to have.
Kent1Cooper
I understand what you're after without a sample drawing, but I have a question:
The first condition is for when two Lines coincide completely [both endpoints the same within tolerance, whether drawn in the same or opposite directions].  In that case, it draws a third Line that also coincides with both [presumably you are in a Layer devoted to the overlap Lines, to distinguish].  Given your description, would you instead want to simply remove one of them?
EDIT:  And a second question:  When two Lines share one end, I assume you would want to leave the shorter one and shorten the longer one [take its end that coincides to the other end of the shorter Line].  So you would have just two Lines as a result.  Is that correct?
Kent Cooper, AIA
Sea-Haven
I may be reading incorrect is it break longer line making 2 and erase shorter line.
rpajounia
I was actually able to make it work with the overkill function thank you for the attempt in help
