Overlap objects, gaps, extra objects...is my current problem in current job, many thanks people who can solve my problem!
I wonder if there is a lisp for delete Overlap objects, gaps, extra objects?
The current command is Overkill but it seem not prefect for me.....the attached file is my problem!
Sea-Haven
My suggestion slow down and draft correctly from the beginning. No excuses for stuff like end of lines not snapping.
nathanwheeler27
I don't think that it is even possible to detect most of those errors. They seem completely random.
ВeekeeCZ
Well, you can create a hatch/boundary with a convenience gap setting, that will allow you to cover most of your flaws.
See HERE It could help but not solve all issues.
john.uhden
I wish I had a hot $#!+ answer for you, but I'm afraid you will have to either improve the drafting skills or include the time for clean-up in your budget.
I do have the following which I found to save a lot of time cleaning up text overwrites...
(defun C:R+M ( / *error* vars vals e obj objname ip rot)
   ;*         R+M.LSP    by     John F. Uhden                                   *
   ;*                           2 Village Road                                  *
   ;*                           Sea Girt, NJ  08750                             *
   ;* * * * * * * * * * * *  Do not delete this heading!  * * * * * * * * * * * *
   ; Program combines rotating and moving text/mtext objects just to save time
   ; adjusting their position for neatness and legibility.
   ; v1.0 (01-17-2020) made for Challoner
   (gc)
   (prompt "\nR+M v1.0 (c)2020, John F. Uhden")
   (defun *error* (error)
      (sssetfirst)
      (mapcar 'setvar vars vals)
      (vla-endundomark *doc*)
      (cond
        (not error)
        ((wcmatch (strcase error) "*CANCEL*,*QUIT*")
          (vl-exit-with-error "\r                                              ")
        (1 (vl-exit-with-error (strcat "\r*ERROR*: " error)))
      (princ)
   ;; Intitialze drawing and program variables:
   (setq *acad* (vlax-get-acad-object))
   (setq *doc* (vlax-get *acad* 'ActiveDocument))
   (vla-startundomark *doc*)
   (setq vars '("cmdecho" "highlight"))
   (setq vals (mapcar 'getvar vars))
   (mapcar 'setvar vars '(0 1))
   (command "_.expert" (getvar "expert")) ;; dummy command
   (while (setq e (car (entsel "\nSelect text object to rotate/move: ")))
     (setq obj (vlax-ename->vla-object e)
           objname (vlax-get obj 'ObjectName)
     (and
       (or
         (wcmatch (strcase objname) "*TEXT")
         (prompt "\nObject selected is not text.")
       (setq ip (vlax-get obj 'InsertionPoint))
       (setq rot (vlax-get obj 'Rotation))
       (princ "\nNew rotation: ")
       (vl-cmdf "_.rotate" e "" "_non" ip "_R" (angtos rot 0 4))
       (while (> (getvar "cmdactive") 0)(vl-cmdf pause) 1)
       (princ "\nNew position: ")
       (vl-cmdf "_.move" e "" "_non" ip)
   (*error* nil)
(defun c:RM ()(c:R+M))
John F. Uhden
Sea-Haven
Like you say there is some lisp out there for cleanup corners with a tolerance, there are just so many problems, the double circles which one do you keep ?
