-OVERKILL command string
frankie_rankin
Message 1 of 8
frankie_rankin
I am currently attempting to write some LISP code to carry out the -OVERKILL, -PURGE, AUDIT and SPELL commands in this specific order in an attempt to make an easy way to clean up drawings in AutoCAD 2023.
Unfortunately, I am having some issues with the -OVERKILL command, specifically simulating the enter key after object selection. I have attempted to use " " and ";" to no effect.
If anyone has any tips on how to get this to work that would be great! I have copied my attempt at coding this below for anyone to check out.
Thank you!
(defun c:CLEANUP ( / )
(princ "\nStarting drawing cleanup...")
(command "-OVERKILL" "ALL" ";" "D")
(princ "\nNo objects to clean with OVERKILL.")
(command "-PURGE" "ALL" "*" "N")
(command "AUDIT" "Y")
(command "SPELL")
(princ "\nCleanup complete.")
(princ)
Replies (7)
Message 2 of 8
-didier-
Bonjour @frankie_rankin
Try with this syntax :
(command "-overkill" "_all" "" "" )
Tell me if it works on your pc please
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 8
frankie_rankin
Hello @-didier-
I have attempted to use that syntax and unfortunately it doesn't seem to work.
it appears to get up to "_all" before being unable to continue.
Message 4 of 8
Kent1Cooper
That works for me.  Could there be a language-version or undefinition problem?  Try "_.-overkill" .  Are there any messages?
Kent Cooper, AIA
Message 5 of 8
paullimapa
works fine on my 2023.1.8
Paul Li
IT Specialist
@The Office
Message 6 of 8
Sea-Haven
Works for me Bricscad.
"" is the equivalent of pressing Enter in a lot of code.
(command "line" pt1 pt2 "")
Message 7 of 8
-didier-
I am surprised by what you are writing about the non-functioning of the line of code.
What reassures me are the answers of the other members who confirm my version.
Try again please.
Amicalement
DA
Message 8 of 8
frankie_rankin
Hi @Kent1Cooper
I just made the change you suggested and it worked right away!
thank you all for your help with this, it's really appreciated
