OUT DOC
OUT DOC
rolisonfelipe
Message 1 of 11
OUT DOC
rolisonfelipe
;;;;;; DCL FOR SELECT MORE OF ONE DOC  E EXPORT IN DESKTOP....
DOC : dialog
{label = "OFFICE";
:row{
: column{
: toggle {label = "DOC X";key = "DOC1"; }
: toggle {label = "DOC Y";key = "DOC1"; }
: toggle {label = "DOC Z";key = "DOC1"; }}}
: button {label = " EXIT " ;key ="BT-SAIR" ;fixed_width=true;width=0;alignment=centered;}
: button {label = "GO DOC" ;key ="BT-GODOC" ;fixed_width=true;width=0;alignment=centered;is_default=true;}
;;;;;LSP
(DEFUN C:DOC ()
(vl-load-com)
(defun Dxf (Index)
(cdr (assoc Index (entget (ssname TxtSet Count))))
);end Dxf
(setq TILE (getvar "DECRITION"));
(setq FILE (strcat "/N,/E," (getvar "DWGPREFIX")))
(setq FLAGOK1 T)
(setq XFIM1 0)
(while FLAGOK1
(new_dialog "DOC" ARQ_DCL)
(action_tile "DOCZ" "(done_dialog 3)")
(action_tile "DOCY" "(done_dialog 2)")
(action_tile "DOCX" "(done_dialog 1)")
(action_tile "BT-SAIR" "(done_dialog 0)")
(action_tile "BT-GODOC" "(done_dialog 100)")
(setq XFIM1 (start_dialog))
(if (= XFIM1 0) (setq FLAGOK1 nil))
(if (= XFIM1 1) ( (cond ((setq TxtSet (ssget '((0 . "*TEXT"))));----SELECTION TEXT START
(cond
((setq File (getfiled "Select Word document" (strcat (vl-filename-base (getvar "dwgname")) ".doc") "doc" 1))
(vl-load-com)
(prompt "\nExport text to Word. Please wait...")
(princ)
(if (not (setq Word (vlax-get-object "Word.Application")));;;is already open ?
(setq Word (vlax-get-or-create-object "Word.Application"));;; no open
(setq Flag#1 T)
);end if
(cond
(Word
(if (not Flag#1) (vla-put-visible Word :vlax-false));;; hide window application
(if (findfile File)
(setq Flag#2 (member (strcase (findfile File)) (GetOpenDocs (vlax-get-property Word 'Documents)))
NewDoc (vlax-invoke-method (vlax-get-property Word 'Documents) 'Open File))
(setq NewDoc (vlax-invoke-method (vla-get-documents Word) 'add))
);end if
(setq Paragraphs (vlax-get-property NewDoc 'Paragraphs) Count 0)
(repeat (sslength TxtSet)
(setq String (vla-get-TextString (vlax-ename->vla-object (ssname TxtSet Count))))
(setq Range (vlax-get-property (vlax-get-property Paragraphs 'last) 'Range))
(if (not (setq FontName (cdar (cdadr (assoc -3 (entget (tblobjname "STYLE" (Dxf 7)) '("ACAD")))))))
(setq FontName (vl-filename-base (cdr (assoc 3 (tblsearch "STYLE" (Dxf 7))))))
);end if
(vlax-put-property (vlax-get-property Range 'Font) 'Name FontName)
(if (= (Dxf 0) "MTEXT") (setq String (ClearMTFormat String)))
(vlax-invoke-method Range 'InsertAfter (strcat String "\n"));<--INSERT-->\n <CENTER BOLD> TITLE \n<CENTER BOLD> FILE \nLOCAL PROJETCT: <BOLD> TxtSet\nMSGbody_DOCZX
(setq Count (1+ Count))
);end repeat
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-saveas (list NewDoc File)))
(prompt "\nProbably selected file is read-only. Cannot export text to this file. ")
(vla-saveas NewDoc File);;; save document
);end if
(cond
((not Flag#1)
(vla-quit Word 0)
(T (if (not Flag#2) (vla-close NewDoc));;; close application
(vla-put-visible Word :vlax-true);;; show application
);end cond
(mapcar 'vlax-release-object (list Word NewDoc Paragraphs Range));;; objects release
(mapcar '(lambda (x) (set x nil)) '(Word NewDoc Paragraphs Range));;; null all variables
(T (prompt "\nCan't create Word document. Microsoft Ofice must be installed. "))
);end cond Word
(T (prompt "\nFile no selected. "))
);end cond
(T (prompt "\nNothing selected. "));;; text no selected
);end cond
(princ))
)));end c:dcc
(defun MSGbody_DOCZX ();;; list of open Word documents
(princ "TO DAY I NEED A LSP FOR JOB...... BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....
\n BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....
\n BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA....BLA...."))
(defun MSGbody_DOCZY ();;; list of open Word documents
(defun MSGbody_DOCZ ();;; list of open Word documents
Replies (10)
Message 2 of 11
Sea-Haven
I had a go at using it, changed the dcl part to as below, this line is a problem (setq TILE (getvar "DECRITION")); so remmed it out. It did not work for me. There were errors also you labelled each key DOC1, there is something wrong with your pick a toggle I stopped at this point debugging.
Word appears to have changed with current version you were abl to do some copy and paste between acad and word but it does not like it now.
(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
(write-line " DOC : dialog " fo)
(write-line (strcat "{ label = " (chr 34) "OFFICE" (chr 34) "; ") fo)
(write-line ": row { " fo)
(write-line ": column { " fo)
(write-line (strcat ": toggle { label = " (chr 34) "DOC X" (chr 34) " ; key = " (chr 34) "DOCX" (chr 34) "; } ") fo)
(write-line  (strcat ": toggle  {label = " (chr 34) "DOC Y" (chr 34) "; key = "  (chr 34) "DOCY" (chr 34) "; } ") fo)
(write-line  (strcat ": toggle { label = " (chr 34) "DOC Z" (chr 34) "; key = " (chr 34) "DOCZ" (chr 34) "; }}} ") fo)
(write-line  (strcat ": button { label = " (chr 34) "EXIT" (chr 34) " ; key =" (chr 34) "BT-SAIR" (chr 34) " ; fixed_width=true ; width=0 ; alignment=centered ; } ") fo)
(write-line  (strcat " : button { label = " (chr 34) "GO DOC" (chr 34)  "; key =" (chr 34) "BT-GODOC" (chr 34) " ; fixed_width=true ; width=0 ; alignment=centered ; is_default=true ; } ") fo)
(write-line "} " fo)
(close fo)
(setq dcl_id (load_dialog fname))
  (if (not (new_dialog "DOC" dcl_id))
    (exit)
; (new_dialog "DOC" ARQ_DCL)
Message 3 of 11
rolisonfelipe
I'm not a programmer, but this fragment you made is too complex to understand, so much more complex than the lsp that I'm trying to edit, but every lsp is a challenge....
....this is the original code.....
;;; CADALYST 08/05 Tip 2053: SaveDoc.lsp Text into a MS Word File (c) Andrzej Gumula
;;; This routine exports selected text to Word document
;;; Microsoft Office must be installed in Windows
;;; Andrzej Gumula
;;; ul. Modrzewiowa 19/54
;;; 40-171 Katowice POLAND
;;; email: a.gumula@wp.pl
(defun c:sd (/ TxtSet Word Docs NewDoc Paragraphs Range
OldTxtList NewTxt IdTxtList FontName Txt Count
Flag#1 Flag#2)
(defun Dxf (Index)
);end Dxf
(defun ClearMTFormat (Str / Item TLength Char New);;; clear mtext format in string
(setq Item 1 TLength (strlen Str) New "")
(while (<= Item TLength)
(setq Char (substr Str Item 1))
(if (= Char "\\")
(progn
(setq Item (1+ Item))
(cond
((member Char '("\\" "f" "F" "C" "H" "S" "T" "Q" "W"))
(while (and (/= Char ";") (<= Item TLength))
);end while
((= Char "P")
(setq New (strcat New "\n"))
((member Char '("{" "}"))
(setq New (strcat New Char))
);end cond
);end progn
(if (not (member Char '("{" "}")))
);end if
);end if
);end while
(cond (New) (T ""))
);end ClearMTFormat
(defun GetOpenDocs (Docs / Item Names);;; list of open Word documents
(repeat (setq Item (vla-get-count Docs))
(setq Names (cons (strcase (findfile (vla-get-fullname (vla-item Docs Item)))) Names))
(setq Item (1- Item))
);end repeat
Names
);end GetOpenDocs
(princ "\nSelect TEXT (MTEXT) to export to Word document: ")
(cond
(cond
(vl-load-com)
(princ)
(setq Flag#1 T)
);end if
(cond
(Word
(if (findfile File)
);end if
);end if
);end repeat
);end if
(cond
((not Flag#1)
(vla-quit Word 0)
);end cond
);end cond Word
);end cond
);end cond
(princ)
);end c:sd
(prompt "\nLoaded new command Save2Doc [SD]. ")
(prompt "\n[c]2004 Andrzej Gumula. ")
(princ)
;************** in the future - maybe in next version ?
;(vlax-invoke-method Range 'InsertSymbol 176 nil) ;degree%%d
;(vlax-invoke-method Range 'InsertSymbol 177 nil t) ;plus-minus%%p
;(vlax-invoke-method Range 'InsertSymbol 216 nil t) ;diameter%%c
Message 4 of 11
john.uhden
I can't even stomach looking at it with no indentation.
John F. Uhden
Message 5 of 11
rolisonfelipe
(close fo)
    (exit)
(close fo)
    (exit)
(close fo)
    (exit)
(close fo)
    (exit)
(close fo)
    (exit)
(close fo)
    (exit)
(close fo)
    (exit)
what I want is that in the dcl I can select more than one doc, and generate them simultaneously because the input base is the same as all texts
Message 6 of 11
john.uhden
I really haven't been paying much attention, but if you put your document
names in a list_box with multiple_select = true then you can select
multiple entries in the list_box.
I think you can even use Ctrl+A to select all, or at least Shift+Arrow down.
John F. Uhden
Message 7 of 11
rolisonfelipe
John F. Uhden, so I can only thank you for your collaboration,  thank you!!!
Message 8 of 11
Sea-Haven
I tried the original code and it works, but its not a true mtext to word as it drops text fonts if you have a mixture in the paragraphs. Not sure if this can be corrected unless looking for all the control strings in Mtext.
The write dcl is a common function that is worth looking into for simple dcl like this task it means that you dont need 2 files a dcl and lisp.
You should always state that the code came from some where even a simple 1 line reference.
; Thanks to Andrzej Gumula Cadalyst tip 2053 for original code
; Modified by BIGAL Jan 2021
Message 9 of 11
rolisonfelipe
ow, sorry for the inelegance, I will do it now, as I didn't notice it in the other posts
Message 10 of 11
Sea-Haven
Thats ok its good to refernce a Author as often they will see and offer more help.
Message 11 of 11
rolisonfelipe
that's the goal, generate docs according to dcl, from one to several docs in a single click, that have the same entry, type: file name, title, and identical strigs the rest and text type \n blablabla\n blablabla\n blablabla..
good observation😎
