Option 'make joined plines'
hanslammerts
Message 1 of 13
hanslammerts
Hi
I have made this routine my own.
Nice thing about it is that it will fillet regardless if you choose a polyline or two lines.
what i would like is to build in a option to make joined polylines if user chooses and picks a line.
any idea for this to implement?
the code can be found as link underneith the video
thanks
https://youtu.be/cof88zOvTes
Replies (12)
Message 2 of 13
john.uhden
Excellent!!
I still can't do without my PJOIN and QJOIN commands.  Enjoy your accomplishments.
John F. Uhden
Message 3 of 13
DannyNL
If you use fillet on a polyline AND a line or vice versa, the end result will be a joined polyline with the fillet.
So what you could do if someone picks a line, first convert that line to a polyline. Easiest way would be (command "PEDIT" line_entity "Y" ""). Use this new polyline entity (= entlast) in your fillet and the end result will be a joined polyline.
Message 4 of 13
john.uhden
Just a reminder to those who may be following...
You don't need/want to supply the "Y" if PEDITACCEPT is turned on (1).
John F. Uhden
Message 5 of 13
ВeekeeCZ
Nice routine!
btw What is that floating osnap panel? Is it your app? Never seen that and like it very much!
Message 6 of 13
hanslammerts
Sharp 😉 you noticed that one.
I liked the button grey / ungrey for osnap which can be found in B..peep..Cad
So i got some help and it worked out whit help of OpenDCL
The nicest thing about this floating osnaps panel is the oZ button
it switches OSNAPZ on/off togetter with a grid. No more doubting if you are working on a plane or in 3D
A grid display with this tool will always mean: 'working on a plane' so with OSNAPZ =1
Demo (early release)
https://youtu.be/mvAVqWTVKAI
Details and download (OpenDCL needed)
http://opendcl.com/forum/index.php?action=post;quote=12212;topic=2446.0;last_msg=12444
Message 7 of 13
ВeekeeCZ
Thanks for sharing. I will definitelly look into it.
Message 8 of 13
that video very helpful may i know how to load DCL file
Message 9 of 13
hanslammerts
Normal DCL files should be put in a 'supported path'
Likewise OpenDCL files being used, the same
the osnaps.lsp calls OpenDCL functions, written down like this..
  ;; Load ODCL and show dialog:
  (if (not (vl-position "Osnaps" (dcl-GetProjects)))
    (dcl-Project-Load "Osnaps")
Have fun with it ! 😉
Message 10 of 13
frans_riemens
thanks for sharing i'm going to use this one.
Message 11 of 13
hanslammerts
hi frans, jij hier 😉
the only downside is that the dyn buttons are not transparent in combination with custom commands.
programmed by a great Lisp programmer from he Netherlands. Off course :p. Can't work without it myself.
Message 12 of 13
ActivistInvestor
Or just use the JOIN command, and don't worry about PEDITACCEPT.
Message 13 of 13
PEDITACCEPT  SET TO 1.
I hate pressing "Y"
Thank you
