Open PDF (or other filetypes) from AutoCAD
toolbox2
Message 1 of 8
toolbox2
I want to define some buttons that will open certain reference documents - usually PDFs.
The following command works fine when entered directly on the Command line but not when added as a macro to a button.
(startapp "explorer c:\\temp\\file.pdf")
I've tried burying the command within a Lisp function. Didn't work.
I've Googled for answers and have got close but still not quite there. Something to do with the backslashes being interpreted as a pause.
Any ideas?
Replies (7)
Message 2 of 8
ВeekeeCZ
Probably just wrong quite marks.
(startapp "explorer" "c:\\temp\\file.pdf")
Message 3 of 8
toolbox2
Fraid not. That works on the command line but not when defined as a macro in a button.
The command pauses here :
The backslashes are causing it to pause.
I've tried replacing the double-backslashes with single forward slashes. The result is that Explorer then opens up on the specified folder but the PDF file doesn't open with the default PDF application.
Using AutoCAD Map 2016, by the way.
Message 4 of 8
ВeekeeCZ
Not sure why... but you try THIS method.
Message 5 of 8
toolbox2
Brilliant! All I needed was to prefix the filepath with "file://".
So, I now have :
(startapp "explorer file://c:/temp/file.pdf")
I haven't explored the lisp in that Civil 3D post but the above solution seems to be working.
Many thanks.
Message 6 of 8
scot-65
Alternate:
(vl-load-com)
(vl-cmdf ".BROWSER" (strcat "\"" %DPATH% a "\""))
where %DPATH% is a hard-path prefix to a specific folder and
a is the full file name with extension.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 7 of 8
toolbox2
@scot-65 wrote:
Alternate:
(vl-load-com)
Thanks for the input.
This code opens the file in my default browser (Chrome). It works but didn't handle MS Word docx files - Chrome just downloaded the file.
The startapp function works wells and opens the file with the system default application. Are there limitations with startapp?
Thanks again.
Message 8 of 8
scot-65
The snippet I provided is intended to open up file(s) that cannot be edited.
By downloading the non-browser able files (such as DOC), the downloaded
file can be edited and the original preserved.
command STARTAPP, to my knowledge, has no limitations.
Scot-65
