Open lisp and search for string
vishshreevT578L
Message 1 of 30
vishshreevT578L
Hi.....
I am looking for source code which will open lisp file and search for prompted string and output will be files name.
For example.....
(DEFUN GETINFO ()
  (SUPERMAN (IF SPIDERMAN T NIL))
My superman function is somewhere in the folder which contains multiple lisps and I want to look for the same function to load it.
Thanks in advance.
Shreev
Replies (29)
Message 2 of 30
jwhite
You may want to let Windows do the searching for you. You need to add the .lsp extension to the file types that are indexed for contents. I don't remember how to do it but a Google search for file indexing for your version of Windows should find something. I use it every so often to find that lisp file that used a command I rarely use.
Message 3 of 30
hencoop
You should use the VLIDE to search for your string within files.  Once the filename is determined, add code to your routine(s) that will automatically load it before it is to be used.
; The second argument of the LOAD function will tell you if the file is not loaded for any reason.
(IF <function> NIL (LOAD <filename> "\nFile <filename> not loaded! ")) ; Load the function
; if <filename> is in your Support File Search Path you do not need to include its path in the LOAD function. (<function>) ; Execute the function
; <function> and <filename> including < and > must be replaced with your specific string values.
Searching so broadly for a string within all of your lisp files is very time consuming.  Each file must be opened and each line must be read to find the match. It is possible to find the same string in more than one file and you can't easily determine which one is what you are looking for.  Once you have found the name of what you are looking for once you don't want to have to ever find it again.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Message 4 of 30
steve_carson
This isn't exactly what you asked for but may accomplish your goal. With the help of some Lee Mac functions I wrote this to search a folder for all lsp and mnl files and print to a text file all of the functions, separated by filename. Just open this lisp file and modify the text file name and path to be whatever you want and load it. Loading the file runs it.
HTH
Message 5 of 30
phanaem
Try the attached lisp. I wrote it to find a specific text inside my lisp files.
You can adapt it to load the files.
(defun search_lsp (str dir sd / file found l line)
  (foreach x (vl-directory-files dir "*.lsp" 1)
    (setq file (open (strcat dir x) "r")
          found nil)
    (while
      (and
        (not found)
        (setq line (read-line file))
      (setq found (wcmatch (strcase line) (strcase str)))
    (if found (print (strcat dir x)))
    (close file)
  (if sd
    (foreach subdir (cddr (vl-directory-files dir "*" -1))
      (search_lsp str (strcat dir subdir "\\") sd)
(search_lsp "*acobj*" "D:\\Lisp\\" T)
The search is not case sensitive and you can use wildcards.
The second argument is the start directory. Note it has to end with "\\".
The 3-rd argument is T or nil, T if you want to search in sub-directories.
Message 6 of 30
scot-65
nice!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 7 of 30
john.uhden
It's not time consuming if you use ZTree.  You simply set the file spec to *.lsp,*.mnl, log as many directories as you wish, hit S (for Showall) and do a Ctrl+T (tag) and Ctrl+S (search) for the the string "defun superman."  ZTree is cheap too.  Plus it let's you view files without opening them and gather lines of text and copy to clip board, and many other things like changing the date and/or time and name and attribute of multiple files at once.  You can copy selected files and even entire directories to anywhere else.  I even have mine set up to ZIP selected files to wherever I want.  Yes, you can select a file and hit O (for Open) if the extension is associated with an installed application.  Plus, if you had some DOS experience, you can hit X (for eXecute) and type in a DOS command like "SET|MORE." to check out your environment.
I would love it if you young dogs could learn some old tricks.
John F. Uhden
Message 8 of 30
vishshreevT578L
Its not working
Shreev
Message 9 of 30
pbejse
@vishshreevT578L wrote:
Its not working
Mind if i ask how did you go about running the posted code? Any error message?  if you don' use wildcards, it will explicitly look for the exact match.
I wont find the string if you' re looking for "banana" and the closest match is "Give me the  banana ", but  "*banana*"
What it's not going to do is load the file if found, it will only print the path(s) on the command line. I had something similar to this long ago. to search for the embedded date (getvar  'CDATE ) . and i think some of you may know the reason for that.
Message 10 of 30
vishshreevT578L
I think my question here is not that much clear, so to make you understand i would like to go in detail,
1) I am trying to work on the current code which is as below,
(defun c:drawaline ()
  (vl-load-com)
  (a)   ;This line is my querry
  (setq x (getpoint))
  (setq y (getpoint x))
  (command "line" x y)
  (princ)
2) Now i have a folder containing nos of lisp files.
For example;
a.lsp
b.lsp
c.lsp
d.lsp etc.,
3) a.lsp file contains
(defun test ()
  (body of program)
  (princ)
(defun test1 ()
  (body of program)
  (princ)
(defun test2 ()
  (body of program)
  (princ)
(defun a ()
  (prompt "click points to draw a line")
  (princ)
4) Here i am looking for a function "(a)" which is written somewhere in the folder which contains nos of lisp file.
5) I need a program which will ask me for a string "what are you looking for? suppose i provide "defun a" so it will open all the lisp files from the selected folder and search for the provided string and will return "your result is in the "a.lsp" file.
I hope i have made the right question.
Thanks in advance...............
Shreev
Message 11 of 30
pbejse
Use the same code shown at post#5 and tweak it a bit to load the file instead of printing on command line AND  modify it to stop evaluation as soon  the "string match" is found,  unless its something unique like "*borkasdmaicus*"
You need help with that?
Message 12 of 30
john.uhden
ZTree...  F "*.lsp";Ctrl+T; Ctrl+S "defun a*"  Then view and pick which file you want to open.
That's the kind of answer you get from old dogs.
But I suppose you want us to build you a LSP routine to look through every folder in every drive for any LSP file that contains "(defun a"
I could do it, but I don't have any need for it.  Plus, I now have a regular job!  YAY!
My apologies for sounding so grumpy.
John F. Uhden
Message 13 of 30
john.uhden
Be careful.  I think *borkasdmaicus* is a Slobovian curse word.
John F. Uhden
Message 14 of 30
vishshreevT578L
Good Morning Sir......
(defun a ()
  (princ)
I have a lisp file which contains the above code "a.lsp" in this location "C:\Users\GAW81683\Desktop\shreev"
when I run your function I get the result nil
(search_lsp "defun a" "C:\Users\GAW81683\Desktop\shreev" T)
error image is attached.
Shreev
Message 15 of 30
pbejse
You are missing "\\"  at the end of the path argument
Message 16 of 30
vishshreevT578L
STILL I AM GETTING NIL
Shreev
Message 17 of 30
vishshreevT578L
CAN YOU TRY THE SAME AT YOUR SIDE
Shreev
Message 18 of 30
pbejse
If you read my reply at post # 9,
".... if you don' use wildcards, it will explicitly look for the exact match.... wont find the string if you' re looking for "banana" and the closest match is "Give me the  banana ", but  "*banana*"
In your case, (search_lsp "defun a" "C:\Users\GAW81683\Desktop\shreev" T), it's searching for "defun a" from the result of read-line function. Now if the lsp file is structured like this
defun a
( / b c d )
(do something)
Then your search will yield a result.
will give you "defun a", but with this
(defun a ( / b c d )
(do something)
will evaluate to nil , line variable value is "(defun a ( / b c d )" which is NOT a match to "defun a"
try (search_lsp "defun a*" "C:\Users\GAW81683\Desktop\shreev" T)
Hang on a minute, i will write a short routinize that may help you.
Message 19 of 30
vishshreevT578L
Alright Sir....
Awaiting for the perfect match..........
Shreev
Message 20 of 30
pbejse
I modify the code to stop when the target lisp is found.
(defun search_lsp (str dir / file found l line f targetdir)
(setq targetdir  (vl-directory-files dir "*.lsp" 1))
	(while (and (null f)
	            (setq x (car targetdir)))
		          found nil)
		    (while
		      (and
		        (not found)
	    	(if found (setq f (strcat dir x)))
	    (close file)
              (setq targetdir (Cdr targetdir))
    f
AND from your example
(defun c:drawaline ( / opt theprogram x y)
  (vl-load-com)
      (initget "a b c")
      	(setq opt (getkword "\nwhat are you looking for [a/b/c]?: "))
      	(if (and (setq theprogram (search_lsp (strcat "(defun " opt "*") "C:\\Users\\GAW81683\\Desktop\\shreev\\"))
                (or (eq (type (eval (read opt))) 'USUBR) (load theprogram))
            	(progn
			(setq x (getpoint "\nPick Point"))
			(setq y (getpoint "\nPick Next Point"))
  (princ)
HTH
