Open drawing by lisp
franc_as
Message 1 of 12
franc_as
I have this lisp routine to open specific drawing:
(defun c:TEST1 ()
(setq acApp (vlax-get-acad-object))
(setq acDocs (vla-get-documents acApp))
(vla-open acDocs "c:/Delo/Test1.dwt")
(princ)
Problem is ... my new opened drawing not become current, but goes in background (active stays my previous working drawing).
I need to make it current, because it is connected with other macro command.
Is it possible to modify my lisp or.... maybe some kind of system variable setting?
Replies (11)
Message 2 of 12
EnM4st3r
im wondering why its not staying active after the open method. It instantly goes back to the drawing the command is running in.
you can try to use vla-put-activedocument. So:
(defun c:TEST1 (/ acApp acDocs)
  (vla-put-activedocument acApp (vla-open acDocs "c:/Delo/Test1.dwt"))
  (princ)
But your lisp will still keep running in the original document so not everything will work.
Message 3 of 12
franc_as
It works ...thank you
Can you help me also... how to add command at the end of this lisp, to save this drawing immediately to other location, with same name as dwg?
For instance to c:/Delo1/Test1.dwg
Message 4 of 12
EnM4st3r
use the SaveAs method.:
(vla-saveas doc "c:/Delo1/Test1.dwg" acNative)
Also you can get the name of the dwg using
(vla-get-name doc)
then combine it with your directory path using strcat. So for example
(setq dir "c:/Delo1")
(setq file (strcat dir "/" (vla-get-name doc)))
(vla-saveas doc file acNative)
you could also add some findfile checks to ensure the directory exists or if there isnt a file with that name already.
Message 5 of 12
franc_as
I put your line ((vla-saveas doc "c:/Delo1/Test1.dwg" acNative)) in lisp:
(princ)
...but it not working, just open dwt and stop. I dont know much about writing lisp, so I am confused by combine your instructions. I must write it wrong.
Could you write whole lisp correct?
Message 6 of 12
EnM4st3r
you didnt save your document in the 'doc' variable so your variable was empty.
(defun c:TEST1 (/ acApp doc)
  (setq doc (vla-open (vla-get-documents acApp) "c:/Delo/Test1.dwt"))
  (vla-put-activedocument acApp doc)
  (princ)
Message 7 of 12
franc_as
Thank you...it is working now.
But one strange thing happened. All palettes (ribbon, properties....) and icons disappeared. Just like use CLEANSCREENON command.
Do you know why?
I solved this situation by inserting line... (command "CLEANSCREENOFF").... at the end of lisp, and it works. Is there any other solution?
Message 8 of 12
EnM4st3r
nothings closing for me. Maybe its your makro?
Message 9 of 12
franc_as
I don't think so... Macro is simple ^C^C_TEST1
I've changed lisp and macro TEST1 to different name, but same result.
Thanks again for your help.
Message 10 of 12
chris.klukan
This works great.
Is there a way do this and open the drawing file read only?
Thank you
Message 11 of 12
EnM4st3r
yes just add :vlax-true add the end.
(vla-open (vla-get-documents acApp) "C:\\Crap\\Drawing1.dwg" :vlax-true)
Message 12 of 12
chris.klukan
Thank you, works great.
Is there a way in the original command to have the read-only dialog box pop up if another person has the drawing open.
