Open border pline tracing
Jonathan_Bell82GXG
Message 1 of 9
Jonathan_Bell82GXG
Is there a way to create a new polyline covering the green layer from one point of intersection with the blue layer to another (the new polyline should be on the same layer as the green entity)?
Replies (8)
Message 2 of 9
paullimapa
Have you tried BPoly command? You can define the objects you want Bpoly to search around to create a new Pline boundary
Paul Li
IT Specialist
@The Office
Message 3 of 9
Jonathan_Bell82GXG
Seems like I run into the same issue as BOUNDARY there- it creates a polyline running across the middle of the entities, rather than the shape I described (unless I'm using it wrong)
Message 4 of 9
paullimapa
Kind of hard to tell what color is what with your gray background screen capture.
My best guess is that you want what I've drawn in RED as the new boundary?
Perhaps share your dwg?
Paul Li
IT Specialist
@The Office
Message 5 of 9
Jonathan_Bell82GXG
I'd like this to be the new boundary:
Message 6 of 9
paullimapa
that's a simple TRIM using the BLUE as cutting EDGE
Paul Li
IT Specialist
@The Office
Message 7 of 9
Jonathan_Bell82GXG
Also I would need to trim the other entity similarly-- cutting out the middle portion so that only an outline of blue and green remain (but leaving the inner black entities untouched)- I would be able to trim 1, but as for trimming the other?
Message 8 of 9
paullimapa
If the other entity you're referring to is the Blue Boundary then yes, just selecting the Green or newly created Red Boundary as the Cutting Edge and that will give you this result:
Paul Li
IT Specialist
@The Office
Message 9 of 9
Kent1Cooper
Just be aware of the effect of having both selected as cutting boundaries, if you want to do it in one Trim command.  If a Polyline is among the cutting boundaries, when you pick on a segment of that same Polyline, only that segment is removed [or part of it, if it is crossed by another cutting boundary object].  So you can either:
A)  select both as cutting boundaries in one Trim command, and pick multiple times on each within the area you want to remove [once in every applicable segment or portion], or;
B)  use two Trim commands, with one selected as cutting boundary and the other picked to be Trimmed to that, anywhere within the part you want removed -- it will take out multiple segments and portions of segments with one pick.
Kent Cooper, AIA
