Oops ... I accidentially put some xrefs on the wrong layer ...
I have a project with 100 sheets in the set...
We use xrefs to manage our revision dates centrally...unfortunately I had accidentially put these xrefs on revision layers (A-REV-01 and A-REV-02) instead of layer 0.
Rather than change this manually ... I would like to write a script to address this issue.
I have never written a script that would select an item (a specific xref and then change its layer)... in this case I have two separate xrefs and to separate layers that i want to move ...
any input would be helpful
hmsilva
Hi jthornton23MF3,
by 'script' do you mean a '*.scr' file?
If so, I so, I think that a '*.scr' file can not do that job...
If you mean a '*.lsp' file, we can't acess sheetsets using Auto/Visual LISP.
An Auto/Visual LISP routine may be written to change xrefs layer to '0' but you can't  use it in sheet set manager, you'll have to open/run the routine in each dwg file...
Henrique
voseo
Hi - Try this...  may work!
(defun c:movexrefstolayerzero ( / ss1 k ss1len ce)
 (setq ss1 (ssget "x" (list (cons 0 "INSERT"))))
 (setq k 0)
 (setq ss1len (sslength ss1))
 (while (< k ss1len)
  (setq ce (ssname ss1 k))
  (if (= 4 (logand (cdr (assoc 70 (entget (tblobjname "block" (cdr (assoc 2 (entget ce)))))))4))
   (vla-put-layer (vlax-ename->vla-object ce) "0")
  (setq k (+ 1 k))
 (princ)
pbejse
