OLE OBJECTS NOT SHOWING IN PDF
I made pdf from dwg file by using script file through script pro for multiple dwgs but ole objects not showing up in pdf.
but whenever i open each dwg and run the script everything is fine. Even when i tried to make pdf for a single dwg through script pro problem exist.
roland.r71
I have no idea. Might it be the way that ScriptPro processes the DWG's (so the OLE's don't get loaded, or something?)
but... why not just create correct page setups & use the batchplot utility?
Just setup the plotter for PDF, save it as "Page Setup" & activate it.
Run batchplot, select your dwg's, create PDF('s) and your done.
Note: You can add the page setup via lisp instead of by hand.
cadffm
Are you using acad.exe as editor (Setting in ScriptPro) or accoreconsole.exe?
In Accoreconsole are OLE is not available, also other "normal" program parts, commands and functions.
(My knowledge is from Version2013, perhaps it changed in the current version)
Sebastian
