Old LISP won't load with APPLOAD in Autocad 2024
hadrien-externe_fayolle
Observer Observer
Observer
Observer
Hello fellow Autocad users,
I have an issue with Autocad 2024 since I updated from 2021 version earlier this year : I can't load my LISP with the APPLOAD command anymore. Error message is "Impossible to load (lisp name).LSP"
What I tried :
installing Visual LISP and Microsoft visual Code extensions -> I'm able to load the LISP through Visual LISP by running it "manually", but nothing with APPLOAD command.
I tied setting LISPSYS from 0 to 2, but no effect on APPLOAD
I attached one of my LISP for you to see if something has to change in the code (dowloaded from LeeMac website)
Thank you if you can help me 🙂 !
ВeekeeCZ
It works flawlessly in my 24.
Try the security setting... secureload 0?
Observer
Observer
Exactly that thank you!
I had to install CAD manager to remove level2 security but now it worked thank you very much!
