Old lisp not working fully in new versions 2022 and above
kresimir.bratusa
Message 1 of 10
kresimir.bratusa
What is the reason that lisp not working on new version Autocad 2022 and above?
I got this error message when I start lisp
In older versions, 2021 and bellow is working properly
Replies (9)
Message 2 of 10
paullimapa
Is the dcl file that generates the on screen dialog box a separate file that accompanies the lisp?
If separate, are both lsp and dcl files placed in location under AutoCAD Support folder?
Could you share the lisp here?
Paul Li
IT Specialist
@The Office
Message 4 of 10
kresimir.bratusa
I share the Lips
All files are in the same folder.
Message 5 of 10
Moshe-A
@kresimir.bratusa ,
Are you familer with OPTIONS (command) Support Files Search Path?
Message 6 of 10
pendean
Community Legend
Community Legend
No issues here in 2022, 2023 nor 2024
Seems to work just fine.
You probably forgot to do something like adding your LISP folder(s) here in OPTIONS after adding them in your SUPPORT FILES SEARCH PATH...
Message 7 of 10
paullimapa
Set SECURELOAD system variable to 0 and now see if it runs
Paul Li
IT Specialist
@The Office
Message 8 of 10
kresimir.bratusa
Yes,
That resolve problem when I add folder with LISP files in Support File Search Path in OPTIONS windows.
Message 9 of 10
kresimir.bratusa
Yes,
No matter that I did not add LISP folder under Trusted Locations.
Message 10 of 10
kresimir.bratusa
To put SECURELOAD system variable to 0 did not helped.
