Offset follow
Offset follow
Lukasvop1
Message 1 of 32
Offset follow
Lukasvop1
Hi guys, I want to ask if is possible do something like this?
This is a common command "Offset" [M]ultiple
Take source Line/PLine and Offset many time, as you want.
But problem is, all distances are measured from source Line/PLine, not last one. In many cases would be more effective measure distance from last created Offset.
Basically, just change offset distance measure type.
Thank you for respond.
Replies (31)
Message 21 of 32
Sea-Haven
If your scaling off an image, did you rescale the image to get close to the true size ? This way if you say pick a distance can say display and change before offset, eg 25.87 use 25.
Are you trying to build new the same exactly then why not measure a real one, or just get some distances write down on a piece of paper. With say rounded values and use those.
Message 22 of 32
Lukasvop1
Exactly, it's way more smooth than measure all distances separately on the paper or next to the drawing.
It little bit looks like macro :
measure distance (e.g. 472.7578) > type rounded number (470) > enter for next one > ...
Message 23 of 32
komondormrex
hello there,
check the compiled version attached. not immaculate but hope it will help you in a way.
Message 24 of 32
Lukasvop1
Perfect, exactly this I want, thank you.
It's very nice see actual value, similar like dynamic input, but when type the value of offset (rounded) first number is skipped, is possible fix this?
Message 25 of 32
komondormrex
unfortunately not, try <space> instead
Message 26 of 32
Lukasvop1
It is a pity, so close to absolute perfect tool..
Message 27 of 32
komondormrex
))) perfectness is mainly unreachable thing, but good tools are always there.
Message 28 of 32
Lukasvop1
Sure, but this is so close.. Is possible add prefix to first letter (mentioned "space") ?
Message 29 of 32
komondormrex
you seemed to misunderstand me. i meant that when you offset dynamically and see real distance, you can press <Space> to get the value of distance in get* function and then correct it to your needs.
Message 30 of 32
Lukasvop1
I understand, but I want little bit hack it, when I start type correct value add prefix before "first pressed number" (press space) or press it twice. It could be a separate script, that runs concurrently with the offset_ lisp. Just simple overcome this defect.
Message 31 of 32
komondormrex
i see) some key except the space preceding numerical input?
Message 32 of 32
Lukasvop1
No
