offset by point
offset by point
Message 1 of 19
offset by point
hi
anyone know how to edit this code? as I want it show previous offset distance every time common start.
like this
Thank you
(defun c:aa (/ off pt1 pt2 pt3 ang)
  ;; Tharwat - 20.Sep.2016	;;
  (if (setq off (getdist "\nSpecify offset distance :"))
    (while (and (setq pt1 (getpoint "\n1st point :"))
                (setq pt2 (getpoint "\n2nd point :" pt1))
                (setq pt3 (getpoint "\nSpecify offset side :"))
                (setq ang (angle pt1 pt2))
      (setq ang (if (minusp (sin (- ang (angle pt2 pt3))))
                  (+ ang (* pi 0.5))
                  (- ang (* pi 0.5))
      (entmakex (list '(0 . "LINE")
                      (cons 10 (trans (polar pt1 ang off) 1 0))
                      (cons 11 (trans (polar pt2 ang off) 1 0)))))
  (princ)
Replies (18)
Message 2 of 19
DannyNL
Here you go
(defun c:aa (/ offprev off pt1 pt2 pt3 ang)
   (if
      (> (setq offprev (getvar "OFFSETDIST")) 0)
      (progn
         (initget 6)
         (setq off (getdist (strcat "\nSpecify offset distance <" (rtos offprev) ">:")))
         (if
            (not off)
            (setq off offprev)
      (progn
         (initget 7)
   (while
      (and
      (setq ang
         (if
            (+ ang (* pi 0.5))
            (- ang (* pi 0.5))
      (entmakex
         (list '(0 . "LINE")
   (princ)
Message 3 of 19
hi @DannyNL, thanks for reply.
code you post look like nothing change, I have to key in offset distance every time common start.Untitled.png
Message 4 of 19
DannyNL
Yes, sorry....my bad.
Forget to add one line of code. Tested in a development drawing, but forgot to reset some manual variables so it seemed like everything worked ok.
But below the modified code that should work. It uses the same system variable as the regular OFFSET command, so in both the OFFSET as the AA command you will get the same previous offset value.
   (if
      (progn
         (initget 6)
         (if
            (not off)
            (setq off offprev)
      (progn
         (initget 7)
         (setvar "OFFSETDIST" off)
   (while
      (and
      (setq ang
         (if
            (+ ang (* pi 0.5))
            (- ang (* pi 0.5))
      (entmakex
         (list '(0 . "LINE")
   (princ)
Message 5 of 19
ronjonp
FWIW .. you could accomplish this with a global variable like so:
  ;; RJP added global default 06-01-2018
  (or *aaglobal* (setq *aaglobal* 1.0))
  (if (setq *aaglobal*
	     (cond ((getdist (strcat "\nSpecify offset distance <" (rtos *aaglobal*) ">:")))
		   (*aaglobal*)
		  (+ ang (* pi 0.5))
		  (- ang (* pi 0.5))
  (princ)
Message 6 of 19
Kent1Cooper
@Anonymous wrote:
anyone know how to edit this code? as I want it show previous offset distance every time common start. ....
You can do the whole thing, including setting the Offset distance before  giving the starting-position Line endpoints [as in your original routine], and  offering the previous Offset distance every time as default, with a whole lot less code -- just this:
(defun C:AA ()
  (command "_.offset" "_erase" "_yes" pause "" "_.line" pause pause "" "_.offset" "" "@" pause "")
[If you don't mind the Offset-distance setting being after  the starting-position Line endpoints are specified, rather than before, it can be even shorter.]
That's if you don't mind its leaving the Offset command in the Erase-the-source mode when it's done.  I'm not sure without some research how AutoCAD remembers the Erase-or-not setting in Offset, so that it could be saved first and restored afterwards, but I imagine it could be, still in a much shorter routine.  Or if you always want it set [or set back] to don't-Erase mode, that could be built in:
(defun C:AA ()
  (command
    "_.offset" "_erase" "_no" "" ""
  (princ)
Kent Cooper, AIA
Message 7 of 19
john.uhden
The major advantage I see of using the OFFSET command, or vla-offset, is that the new object gets all the properties of its parent.  Plus, it can be used on objects other than lines.
John F. Uhden
Message 8 of 19
@DannyNL thanks for help.
After tried it, i find out command always remember 1st time distance but not previous distance, can change it to remember previous distance? thank you.
Message 9 of 19
john.uhden
Let's say your variable name for the offset distance is OFF.
Each time you set a new value for OFF, (setvar "offsetdist" OFF).
John F. Uhden
Message 10 of 19
@john.uhden thanks for reply
so have to add in (setvar "offsetdist" OFF) ? sorry, i'm not really understand what you means.
now the command always remember 1st offset distance value
example:
1st value = 2
2nd value = 4
3rd value = 5
4th value = 8
command always remember 1st value 2 even i already change to 2nd, 3rd ... value.
Message 11 of 19
DannyNL
Just move the setting of the variable outside the IF as in the code below.
That way it will always save the last used setting.
   (if
      (progn
         (initget 6)
         (if
            (not off)
            (setq off offprev)
      (progn
         (initget 7)
   (while
      (and
Message 12 of 19
DannyNL
Yes, this is also possible but why use a global LISP variable if AutoCAD has a dedicated offset variable for this on his own?
It will save you a small amount of code, but using OFFSETDIST in this case is better.
Message 13 of 19
thank you very much.
Message 14 of 19
DannyNL
You're welcome & glad I could help Smiley Happy
Message 15 of 19
Kent1Cooper
@DannyNL wrote:
.... why use a global LISP variable if AutoCAD has a dedicated offset variable for this on his own? ....
{and}
   (if
      (progn
         (initget 6)
         (if
            (not off)
            (setq off offprev)
      (progn
         (initget 7)
   (while
      (and
I agree with the first quote above, which makes me wonder about the second -- I don't understand going to all the trouble to build all of that, when the Offset command itself handles it without any additional code.  See Message 6, which allows it to do so.  Only if you want to keep track of an Offset distance for use with this command, separate from  regular Offset's distance, as a global variable, would it seem worth doing.
Kent Cooper, AIA
Message 16 of 19
ronjonp
Agreed .. I'd change it to something like this:
  (setq off (getvar 'offsetdist))
  (if (setq off	(cond ((getdist (strcat "\nSpecify offset distance <" (rtos off) ">:")))
		      (off)
		  (+ ang (* pi 0.5))
		  (- ang (* pi 0.5))
  (princ)
Message 17 of 19
DannyNL
All roads lead to Rome @Kent1Cooper, you should know that Smiley Happy
I've not built anything, I've just modified the already existing code of the OP to suite his feature request.
Message 18 of 19
DannyNL
That would be a way to go, but there is still missing something.
OFFSETDIST always has a value, but it will be -1.00 when it has not been previously used. So you'll need to check for that value as well and only give the value as an option if it's greater than 0.0.
And the last OFF value will need to be saved back to OFFSETDIST, so it can be used as the default value the next time.
Message 19 of 19
ronjonp
You are correct. I need more coffee this morning LOL. Smiley LOL
Take three:
  (and (<= (getvar 'offsetdist) 0) (setq off (setvar 'offsetdist 1)))
  (initget 6)
  (setq	off (abs (cond ((getdist (strcat "\nSpecify offset distance <" (rtos off) ">:")))
		       (off)
  (setvar 'offsetdist off)
		(+ ang (* pi 0.5))
		(- ang (* pi 0.5))
  (princ)
