OFFSET AND CHANGE COLOR RETAINING PARAMETER
Good day,
I would like to ask if any one of you know how to offset and change the color but retaining old parameter if command is repeated? I already have the ColorOffset lisp, but the problem with it is that it does not retain the previous distance given. Does any of you know how the code for it to retain previous distance? or if there is an existing lisp like this? Thanks in advance. If I made a mistake, please do enlighten me.
pbejse
HYG
Where d is the variable name for distance and should not be declared as local
(setq d (cond ((getdist
        (strcat "\nEnter Distance <" (rtos (setq d
              (cond ( d ) ( 100.00 ))) 2 ) ">: "
    ( d )
Let us know if you need more help
And Welcome to the forum @Anonymous  🙂
Thanks pbejse, but can i just insert in this program? this is the ColorOffset Lisp that i am using. I'm kinda new to codes, i tried inserting the code you gave but it confuses the program.
(defun c:ccd ( / cmd off ent entna pk entn )
(setq cmd (getvar "CMDECHO"))
(setq OFOK 1)
(setq ENOK 1)
(setq off (getdist "\noffset distance:"))
(if (= off nil)
(setq OFOK 0))
(if (= OFOK 1)
(setq ent (entsel "\nselect object to offset:")))
(if (= ent nil)
(setq ENOK 0))
(if (and (= OFOK 1)(= ENOK 1))
(progn
(setq entna (nth 0 ent))
(redraw entna 3)
(setq ent (nth 1 ent))
(setq pk (getpoint "\nside to offset?"))
(setvar "CMDECHO" 0)
(command "_.OFFSET" off ent pk)
(command)
(command)
(setq entn (entlast))
(command "_.CHANGE" entn "" "_P"
"_C" (getvar "CECOLOR")
"_LA" (getvar "CLAYER")
"_LT" (getvar "CELTYPE")
(setvar "CMDECHO" cmd)
(redraw entna 4)
(princ)
pbejse
(defun c:ccd (/ cmd  ent entna pk entn)
 ;; (setq OFOK 1)
 ;; (setq ENOK 1)
 (initget 6)
 (setq off (cond ((getdist
		(rtos (setq off
              (cond ( off ) ( 1.00 ))) 2 ) ">: "
	    ( off )
;;; You dont need this now as off will always have a valie
;;;  (setq off (getdist "\noffset distance:"))
;;;  (if (= off nil)
;;;    (setq OFOK 0)
;;  (if (= OFOK 1)
  (if
;  (if (= ent nil)
;;;    (setq ENOK 0)
;;  (if (and (= OFOK 1) (= ENOK 1))
    (progn
      (redraw entna 3)
      (command)
      (command)
	       "" "_P" "_C"
	       (getvar "CECOLOR") "_LA"
	       (getvar "CLAYER") "_LT"
	       (getvar "CELTYPE") ""
      (redraw entna 4)
  (princ)
We can also use the system variable OFFSETDIST for the default. but for now we will stick with the above approach
HTH
Thank you very much pbejse, it works like a treat.
pbejse
Good for you, hope you learned from it as well
You are welcome @Anonymous
