Offset A Starting Point At A Relative Distance From A Reference Point Setting
I use AutoCAD 2021. Starting with a rectangle, say 10" by 20", I want to make a vertical line 3" to the left of the upper-right point. I select the Line tool, hover over the upper-right corner until it reads "Endpoint", and I drag my cursor to the left because I want a known distance from the corner point. However, the input it gives me is the absolute coordinate system. I want it to display (and give me an input) a distance away from the point, so that I can move the cursor to the left and type in "3" for my inches offset, have it snap the first point there, and allow me to continue drying my line. This is similar to "@" at the start of the distance, but I want to change the setting, not type in a command every time I want to make a line.
I spent two hours trying to find this setting. I want to change the setting for all uses of this offset distance, not just a command to do it one time or having to continuously put in the command. If anyone could show me the setting, I'd e grateful. Thanks.
