ObjectDBX - draw lines in a virtual "acdbObj" and copy them back to "acadObj"
surfer96
Message 1 of 8
surfer96
I would like to use ObjectDBX in order to generate multiple "virtual" lines in an "acdbobj" and finally copy them back to the current AutoCAD document.
Is it possible to generate a line in "acdbobj" simply using:
(setq lineObj (vlax-invoke (vla-get-ModelSpace (vla-get-Database doc)) 'addline pt1 pt2)
Is "acdbobj" what is usually called the database object?
The purpose of this test is to find out, wether using ObjectDBX will fasten looping.
(vl-load-com)
(defun c:addrdlines (/ bw nl r1 r2 pt1 pt2 lineObj dbp)
  (setq	acadObj	   (vlax-get-acad-object)
	c_doc	   (vla-get-Activedocument acadObj)
	modelSpace (vla-get-ModelSpace c_doc)
  ;; Load the ObjectDBX library
  (if (= acLibImport nil)
    (progn
      (vlax-import-type-library
	:tlb-filename
	"C:\\Program Files\\Common Files\\Autodesk Shared\\axdb21enu.tlb"
	:methods-prefix
	"acdbm-"
	:properties-prefix
	"acdbp-"
	:constants-prefix
	"acdbc-"
      (setq acLibImport T)
  ;; Create a reference to the ObjectDBX object
  (setq acdbObj (vlax-create-object "ObjectDBX.AxDbDocument.21"))
  (setq	bw 100.				;box width
	nl 10				;number of lines
  ;; CREATE LINES IN MODELSPACE OF acdbObj
;; ??? (repeat nl (setq r1 (* (LM:rand) bw) r2 (* (LM:rand) bw) pt1 (list 0. r1 0.) pt2 (list bw r2 0.) ) (setq lineObj (vlax-invoke modelSpace 'addline pt1 pt2)) ;random line / distance between points ) ;end repeat ;; COPY ALL LINES FROM MODELSPACE "acdbObj" to MODELSPACE "acadObj"
;; Close the in memory drawing
(vlax-release-object acdbObj) ) ;end defun ;;;LM:rand (defun LM:rand (/ a c m) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date)) ) ) ) m ) ) (/ $xn m) )
Replies (7)
Message 2 of 8
surfer96
The code below shows what I got so far, but unfortunately it returns:
error: bad argument type: VLA-OBJECT nil
(vl-load-com)
(defun c:addrdlines (/ bw nl r1 r2 pt1 pt2 lineObj)
    (progn
	:tlb-filename
	:methods-prefix
	"acdbm-"
	:properties-prefix
	"acdbp-"
	:constants-prefix
	"acdbc-"
  (repeat nl
    (setq
      r1  (* (LM:rand) bw)
      r2  (* (LM:rand) bw)
      pt1 (list 0. r1 0.)
      pt2 (list bw r2 0.)
		    (vla-get-ModelSpace acdbObj)
		    'addline
		    pt1
		    pt2
    )					;random lines
  )					;end repeat
  ;; Copy objects
  (vlax-for eachObj (vla-get-ModelSpace acdbObj)
    (vlax-safearray-put-element objCollection count eachObj)
    (setq count (1+ count))
  ;; Copy object and get back a collection of the new objects (copies)
  (setq	retObjects
	 (vla-CopyObjects
	   acdbObj
	   objCollection
	   (vla-get-ModelSpace (vla-get-Database c_doc))
  (vla-ZoomExtents acadObj)
  (alert "Model space objects copied.")
)					;end defun
;;;LM:rand
	a   1664525.0
	c   1013904223.0
	$xn (rem (+ c
		    (* a
		       (cond ($xn)
			     ((getvar 'date))
		 m
  (/ $xn m)
Message 3 of 8
CodeDing
@surfer96 ,
While I may not answer your question directly, to my knowledge ENTMAKE/ENTMAKEX are the fastest ways to create lines in AutoCAD. Faster than VL/VLA/VLAX.
(setq lineObj (entmakex (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt2))))
User tests
User Tests
Best,
~DD
Message 4 of 8
surfer96
@CodeDing
I think velocity depends on what you want to do with the geometry created later on.
By accident I tried the following alternatives today:
(entmakex (list '(0 . "line") (cons 10 pt1) (cons 11 pt2))
(setq lineObj (vla-AddLine modelSpace pt1 pt2))
Multiple random lines were created and the distance between their endpoints and startpoints evaluated.
'addline and entmake had the same speed, whereas vla-AddLine was very much slower due to the complex distance calculation for vlax-3d-points.
I therefore chose the vla-AddLine method to find out if it can be further accelerated by using ObjectDBX...
Message 5 of 8
CodeDing
@surfer96 ,
For what it's worth, it appears "vlax-invoke" is possibly obsolete, and "vlax-invoke-method" is the updated version. Try this?
Message 6 of 8
surfer96
The new "vlax-invoke-method" does not seem to make a difference.
Moreover the object collection variable (to collect all lines to be copied) had not been defined but there still must be errors in the code. I wonder if the lines are properly generated in acdbObj at all.
  ;; define safearray for objects
  (setq	objCollection
	 (vlax-make-safearray
	   vlax-vbObject
	   (cons
	     0
	     (- (vla-get-Count (vla-get-ModelSpace acdbObj)) 1)
	count 0
  ;; put elements to selfarray
Message 7 of 8
surfer96
I found a solution using "vla-addline" instead of "vlax-invoke-method 'addline".
Creating 1000 lines was not faster, but even slower with ODBX:
With ODBX
Command: REPEAT_RDLINES_ODBX
Number of Lines:1000
Time Elapsed in Millisecs: 250
Millisecs per Loop:4
Without ODBX
Time Elapsed in Millisecs: 187
Millisecs per Loop:5
Message 8 of 8
CodeDing
@surfer96 ,
Glad you got your solution! Also, this may seem tedious but based on your equation in your lisp, this:
"Millisecs per Loop:"
Should actually say this:
"Loops per Millisecond:"
