ObjectDBX and check if PROXYGRAPHICS = 1
mdhutchinson
Advisor Advisor
mdhutchinson
I need some quick code... can someone assist?
I'd like to check if certain dwgs have been saved with PROXYGRAPHICS. Help says this setting is saved in the drawing.
(getvar "PROXYGRAPHICS")
hmsilva
With ObjectDBX, we can't access to System Variables...
Not fast, but perhaps something like this.
;; usage
;; (get_prox "C:\\some\\path\\")
(defun get_prox (path / dwg dwg_lst lst val)
  (if (and (findfile (vl-string-right-trim "\\" path))
           (setq dwg_lst (vl-directory-files path "*.dwg"))
    (progn
      (foreach x (vl-directory-files path "*.dwg")
        (setq dwg (vla-open (vla-get-documents (vlax-get-acad-object)) (strcat "\"" path x "\"") :vlax-true))
        (if (/= (setq val (vlax-variant-value (vla-getvariable dwg "PROXYGRAPHICS"))) 1)
          (setq lst (cons (list x (itoa val)) lst))
        (vla-close dwg :vlax-false)
      (if lst
        (princ lst)
        (princ "\nAll dwgs with PROXYGRAPHICS = 0... ")
  (princ)
Hope this helps,
Henrique
