object selected by lisp in all drawings ..
jaggisingh003
Message 1 of 25
jaggisingh003
PLZ HELP me in this, Here a code I m working for selection of specific text to transfer their values to insert attribute blocks placed at different points by this code In Different drawing variables change and values mismatched..
Plz help..
(defun C:ACC (/ ss e pt pt1 i p1 p2 p3 p4 p5 p6)
(setq pt1 (getpoint "\nSelected point for CONDUCTOR DETAILS CO-ACC"))
(command "_.insert" "CO-ACC" "_S" 1 "_R" 0 "_NONE" pt1)
(setq s2 (entlast))
(setq ss (ssget '((0 . "text"))))
(setq i 0)
(repeat (sslength ss)
(setq e (ssname ss i))
(setq p1 (cdr (assoc 1 (entget e)))))
(setq ss (ssdel e ss))
(setq p2 (cdr (assoc 1 (entget e))))
(setq p3 (cdr (assoc 1 (entget e))))
(setq p4 (cdr (assoc 1 (entget e))))
(setq p5 (cdr (assoc 1 (entget e))))
(setq p6 (cdr (assoc 1 (entget e))))
(setpropertyvalue s2 "ch-1" p2)
(setpropertyvalue s2 "loc-1" p6)
(setpropertyvalue s2 "ch-3" p1)
(setpropertyvalue s2 "loc-3" p4)
(setq pt (getpoint "\nSelected point for SCHEMATIC DIAGRAM SC-ACC"))
(command "_.insert" "SC-ACC" "_S" 1 "_R" 0 "_NONE" pt)
(setq s1 (entlast))
(setq s (entsel "\nSelect exiting ACC1 block" )); Select exiting ACC1 block
(setQ TL1 (getpropertyvalue (car s) "TENSION_LENGTH1"))
(setQ TL2 (getpropertyvalue (car s) "TENSION_LENGTH2"))
(setQ MC1 (getpropertyvalue (car s) "MAST_COUNT1"))
(setQ MC2 (getpropertyvalue (car s) "MAST_COUNT2"))
(setpropertyvalue s1 "TENSION_LENGTH1" TL1)
(setpropertyvalue s1 "TENSION_LENGTH2" TL2)
(setpropertyvalue s1 "MAST_COUNT1" MC1)
(setpropertyvalue s1 "MAST_COUNT2" MC2)
(setpropertyvalue s1 "ch-2" p3)
(setpropertyvalue s1 "loc-2" p5)
Replies (24)
Message 21 of 25
jaggisingh003
@pbejse  If you have some time please explain this remain code .. that would be a great help.
(mapcar '(lambda (c d)
(setpropertyvalue
(if (member c '("LOC-2" "CH-2"))
s1 s2) c d) d )
'("ch-1" "loc-1" "CH-2" "LOC-2" "ch-3" "loc-3" )
(mapcar 'cadr
(vl-sort data '(lambda (a b)
(< (caar a)(caar b)))))
Message 22 of 25
jaggisingh003
@pbejse
thanks in advance
(setpropertyvalue
s1 s2) c d) d )
(mapcar 'cadr
Message 23 of 25
pbejse
@jaggisingh003 wrote:
@pbejse
Yes I did say if i have time didnt I? is your question about mapcar/lambda in general?  I'm not going to spend time explaining all that.
As for the code you posted
(vl-sort data
	 '(lambda (a b)
	    (< (caar a) (caar b))
((-9793.44 Y Z) "160/223.50") ;<--- a
((-9726.75 Y Z) "160/291.00") ;<--- b
((-9659.65 Y Z) "160/354.00")
((-9659.65 Y Z) "160/6")
((-9657.22 Y Z) "160/5")
((-9790.85 Y Z) "160/4")
;;	variable "a" value is
(car a)
	(-9793.44 Y Z)
(car (car a))
	-9793.44
;;	variable "b" value is
(car b)
	(-9726.7	5 Y Z)
(car (car b))		;<-- first item or the first item
	-9726.75
(< -9793.44 -9726.75)	;<-- sort by this item
or simply
(car (Car x)) = (caar x);<--- Each a represents a call to car and each d represents a call to cdr
The result is a sorted list based on X coordinate value.
((-9793.44 Y Z) "160/223.50")  <--- lowest X value
((-9724.72 Y Z) "160/5")
((-9657.22 Y Z) "160/6")  <--- highest X value
Not really sure [ so dont quote me on this ], but I think vl-sort is using "insertion sort" algorithm,  it is slow compared to a well written sorting algorithm using say a while function.
About Point Lists (AutoLISP)  <-- read this
As for this line
(mapcar 'cadr
	[ the data above ]
Will give you a list of every 2nd item ( cadr ) of a given list
("160/223.50" "160/4" "160/291.00" "160/5" "160/354.00""160/6")
Mapcar always returns a list.
And that is all the time I have for today, its Sunday after all.
HTH
Message 24 of 25
Sea-Haven
Pbejse, converted fortran Bubblesort to lisp like 30 years ago no idea where code is now.
Message 25 of 25
pbejse
I for one would want to see that code,  sometimes a code written 10 years ago feels likes yesterday and then I wonder where I saved the file. 😄
