Visual LISP, AutoLISP and General Customization
Number of objects selected?
16 REPLIES 16
Message 1 of 17
9808 Views, 16 Replies
I'm looking for a LISP function that can tell me how many objects I've
selected.
Example: I have a drawing with 134 squares and 35 circles. I select all the
shapes except the 35 circles. It would be nice if Autocad could tell me that
I've selected a total of 134 objects.
Can it be done?
Thanx.
-M
16 REPLIES 16
Message 2 of 17
i've no solution with lisp, but a tip for getting that with standard acad.
if you have opened the properties-window, you always have the number of
selected objects on top of your properties-windows within a combobox, if you
open/click the combobox you get the sum of selected entites for each
entity-type.
- alfred -
"Eowyn" schrieb im Newsbeitrag
news:EC7ACBA09CE8B63DA5197C15B4CA2083@in.WebX.maYIadrTaRb...
> selected.
the
that
> Can it be done?
> Thanx.
> -M
Message 3 of 17
Why do you need a lisp ? when you do a selection in AutoCAD, it does tell you
how many objects you selected. So what's your point ?
> selected.
> Can it be done?
> Thanx.
> -M
Message 4 of 17
No lisp needed. Try using the SELECT command.
-Jason
Member of the Autodesk Discussion Forum Moderator Program
> selected.
the
that
Message 5 of 17
When I have a large, detailed drawing - it would be an advantage to select
object and still have them selected when using the zoom and pan tools. Using
the properties-window works fine as long as I can mark every object without
zooming/pan'ing/anything - but most often that woun't work because of the
number of details in the drawing.
To ask it in a different manner - is there a way to keep objects selected
while moving around in the drawing?
-M
"Alfred NESWADBA" skrev i melding
news:6ABDD89D5A06060F3981E71F9AA6B212@in.WebX.maYIadrTaRb...
you
> entity-type.
> - alfred -
> > selected.
> the
> that
> > Can it be done?
> > Thanx.
> > -M
Message 6 of 17
At the command line, you could type:
(setq ss (ssget))
select your objects, do your panning, zooming, etc...
Then at any other "select objects" prompts just type:
!ss
to pass the selection set to the new command. To be a little fancier, you
might want to add '(setq ss (ssget)) to a toolbar button.
HTH,
- Andrew Levan
"Eowyn" wrote in message
news:75B0A90F18FD85EFA5EFF66652CFD5E1@in.WebX.maYIadrTaRb...
Using
without
> -M
acad.
> you
> > entity-type.
> > - alfred -
> > > selected.
all
> > the
me
> > that
> > > Can it be done?
> > > Thanx.
> > > -M
Message 7 of 17
Also-
Have you tried issuing your zoom, pan, etc. instructions transparently?
Example:
Select objects:'zoom
>>Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window] :
Select objects: 'pan
>>Press ESC or ENTER to exit, or right-click to display shortcut menu.
HTH,
-Andrew Levan
Using
without
> -M
acad.
> you
> > entity-type.
> > - alfred -
> > > selected.
all
> > the
me
> > that
> > > Can it be done?
> > > Thanx.
> > > -M
Message 8 of 17
I'm sure this question is asked before and probably solutions presented.
Check google. I assume this problem exists for those using digitizers or
traditional mice, or trying to use toolbars or commands for panning and
zooming.
I've never seen this problem cause I use a trackball with scroll wheel and
it does exactly that, you can select and zoom and pan to your hearts
content without losing your selections. I cant' imagine any other way of
working after using this tool.
I assume even a mouse with scroll wheel would do this.
good luck
Mark
Message 9 of 17
No trouble here 😉
-Jason
Message 10 of 17
Do some research on the redraw function. You will find what you need.
Message 11 of 17
(setq ss (ssget "X" '((0 . "~CIRCLE")))
n (sslength ss))
(alert (strcat "You have selected " (itoa n) " objects."))
___
> selected.
the
that
> Can it be done?
> Thanx.
> -M
Message 12 of 17
Clarification needed...
When you say "select" do you mean as part of a command, or do you mean gripping?
John Uhden, Cadlantic/formerly CADvantage
http://www.cadlantic.com
Sea Girt, NJ
> selected.
> Can it be done?
> Thanx.
> -M
Message 13 of 17
This might interest you:Its a simple (and not-very-professional)program
that lists how many of each type of entity you select
. I use it when I receive a dwg from somebody else,and want to freeze
one of his layers. For example, I wnat to make sure that his layer
called Dims has nothing but dimensions on it.
You might want to try this:use the select command, then run this lisp
on the previous selection, then get on with your work. A bit
awkward,but hey, its better than nuttin'.
> selected.
Message 14 of 17
This is a roundabout way of doing it. But, if the object you are trying to count is a closed object, you can use the Region command to turn it into a region. Once you do this, the screen will say how many regions were generated. Simply undo if you do not wish for your objects to become regions.
Message 15 of 17
roland.r71
Smiley LOL ROFL
The (A) correct answer being:
(if (setq ss (ssget "_I"))(sslength ss))
Your 'solution' is pretty exotic, I'll give you that.
... but ok, Welcome to the forum! Smiley Wink
Message 16 of 17
i am using simple method, select the object and just say delete then see the command box it will show  you how many object deleted, after make 'undo'😁
Message 17 of 17
Kent1Cooper
The simplest way of all [now*] is to simply have the Properties palette up.  [I do all the time anyway.]  If you have things selected, it reports directly how many:
The "All" indicates that there's more than one object type among the selection -- if they're all of one kind, it will show that directly.  If it's All, and you pick the pull-down, it breaks it down and tells you how many of each of the different object types involved.
* This may not have been available in 2002 when this thread originated.
Kent Cooper, AIA
Autodesk Customer Advisory Groups
