Visual LISP, AutoLISP and General Customization
Not sure how to do this...
9 REPLIES 9
Message 1 of 10
1174 Views, 9 Replies
Hi, so I have a working C++ program which creates a SCR file which I have to manually insert into the DWG file.
How can I apply the SCR file automatically to the DWG file?
9 REPLIES 9
Message 2 of 10
dlanorh
What is the SCR file? Normally SCR files are script files (lists of autocad commands) that need to be run, not inserted.
I am not one of the robots you're looking for
Message 3 of 10
in reply to: dlanorh
the the SCR is a list of insert commands which has the location of the block and the vector to insert it in the the dwg.
what to insert and where is controled
by the program.
Message 4 of 10
JustoAg
You could try any of this:
- From the C++ program, try to open a new AutoCAD with the scr file as a command line parameter, use /b.
- From AutoCAD use the SCRIPT command'
- From AutoCAD run a lisp routine to invoque the script command as the last thing.
- From AutoCAD use a SHELL command to run the C++ progr and then the Script command.
Regards.
Message 5 of 10
in reply to: JustoAg
Thanks, the first option is the easiest for my opinion, I didnt know that I can open a new dwg and run scr as it opens...
Could you give me a code example or link to a tutorial video?
Message 6 of 10
cadffm
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-CE4A928E-FDB1-470A-8176-32ABD1E3C6A1
and links below. You need parameter /s "d:/mypath/myscript.scr"
For batchjobs is accoreconsole.exe interesting, but who works with it must know a few things more. The safe simple method is the acad.exe or tools like scriptpro.
Sebastian
Message 7 of 10
in reply to: cadffm
Thak you, I got the idea. I'm not a programmer, I'm just a lazy electrical engeener so I dont know many tools, just the basics, I learn on the go...
Message 8 of 10
JustoAg
Maybe possible with something like ShellExecute(NULL, "open", "path\\to\\acad.exe", NULL, NULL, SW_SHOWDEFAULT);
There are other methods more complicated with COM interfaces, IAcadApplication and so. Try to use it at the end of your c++ code.
The command line parameter is /b (former /s), it seems they changed it at some point.
Message 9 of 10
cadffm
No it was ever /b in my remember.
Sorry, misspelled in the hustle, but in my link it's perfectly documented.
Why I wrote the wrong one because for the accoreconsole.exe the switch is really / s
Sebastian
Message 10 of 10
JustoAg
in reply to: cadffm
You're right. It was always /b to run a script.
AutoCAD Inside the Factory
