Not able to change Paper space Background
The below code can toggle mode space background from white to black and vice versa. But not working in paper space (defun c:TBG ( / col ) (if tbg:flg (setq col 16777215 tbg:flg nil) (setq col 0 tbg:flg t ) ) (foreach prp '(graphicswinmodelbackgrndcolor modelcrosshaircolor) (vlax-put-property (acdisp) prp (setq col (- 16777215 col))) ) (princ) ) (defun acdisp nil (eval (list 'defun 'acdisp 'nil (vla-get-display (vla-get-preferences (vlax-get-acad-object))) ) ) (acdisp) ) (vl-load-com) (princ) (defun c:TB8 () (vl-load-com) (setq disp (vla-get-display (vla-get-preferences (vlax-get-acad-object)))) (setq drafting (vla-get-drafting (vla-get-preferences (vlax-get-acad-object)))) (vla-put-GraphicsWinModelBackgrndColor disp 5987163) (vla-put-GraphicsWinLayoutBackgrndColor disp 5987163) (vla-put-LayoutCrosshairColor disp 16777215) (vla-put-ModelCrosshairColor disp 16777215) (vla-put-AutoTrackingVecColor disp 16777215) (vla-put-AutoSnapMarkerColor drafting 2) (princ) ) Requesting you to please update the code.
Can anybody please help me, as it is in very urgent requirement.
ronjonp
Well since its urgent! Smiley LOL
(defun c:tbg (/ col)
  (if tbg:flg
    (setq col 16777215
	  tbg:flg nil
    (setq col 0
	  tbg:flg t
		 modelcrosshaircolor
		 graphicswinlayoutbackgrndcolor
		 layoutcrosshaircolor
  (princ)
(defun acdisp nil
  (eval (list 'defun 'acdisp 'nil (vla-get-display (vla-get-preferences (vlax-get-acad-object)))))
  (acdisp)
(vl-load-com)
(princ)
(defun c:tb8 ()
  (vl-load-com)
  (vla-put-graphicswinmodelbackgrndcolor disp 5987163)
  (vla-put-graphicswinlayoutbackgrndcolor disp 5987163)
  (vla-put-layoutcrosshaircolor disp 16777215)
  (vla-put-modelcrosshaircolor disp 16777215)
  (vla-put-autotrackingveccolor disp 16777215)
  (vla-put-autosnapmarkercolor drafting 2)
  (princ)
Thanks a lot Sir.
ronjonp
@Anonymous wrote:
Thanks a lot Sir.
You're welcome.
