not a valid path using %username% in printer file support path
ian
Message 1 of 12
ian
Good Afternoon.
I having a problem with my lisp file.  I have have managed to set up to add trusted and support file paths, using the %username% in the file paths.  We are needing to update the paths because we are moving from network drives to SharePoint/OneDrive.  We want everyone to link to files on SharePoint, via the one drives.  so each path needs to contain individual usernames when loading.
It all works with the exception of the Printer support paths.  has anyone any idea what I'm missing?
;(vla-get-PrinterDescPath *files*)
(vla-put-PrinterDescPath *files* "C:\\Users\\%username%\\OneDrive - ###############\\02_Model and Design Support\\AutoCAD_Support Folder\\Plotters\\PMP Files;")
Replies (11)
Message 2 of 12
pbejse
try  %userprofile%
Message 3 of 12
pendean
Community Legend
Community Legend
(strcat (getenv "userprofile") "\\OneDrive\\xyz") if you're already logged into OneDrive.
Message 4 of 12
ian
Thanks for the response's, but I'm still don't seem to be having any look with this.  still getting an error to say it does not exist.
It defiantly does
Message 5 of 12
pbejse
(setq *files* (vla-get-files (vla-get-preferences (vlax-get-acad-object)))
(vla-put-printerdescpath *files* "%userprofile%\\DC\\YourPath")
Message 6 of 12
ian
am i just replacing the YourPath with "C:\\Users\\%userprofile%\\OneDrive - ########\\02_Model and Design Support\\AutoCAD_Support Folder\\Plotters\\PMP Files
or replacing the whole thing, "%userprofile%\\DC\YourPath" with the above?
what does the DC stand for?
Message 7 of 12
pbejse
DC is just an example i used for this demo.
%userprofile% represents this part of the path  "C:\\Users\\pbejse"
This
"%userprofile%\\OneDrive"
 is read as
"C:\\Users\\pbejse\\OneDrive"
HTH
Message 8 of 12
ian
(vla-put-printerdescpath *files* "%userprofile%\\OneDrive - ##########\\02_Model and Design Support\\AutoCAD_Support Folder\\Plotters\\PMP Files"
  Still not having any look I'm afraid
Message 9 of 12
ronjonp
@ian
See @pendean response #3. (getenv "userprofile")
Message 10 of 12
ian
still having no luck with this.
All i can get to input to the path location is %userprofile%\OneDrive - Asda Stores Limited\02_Model and Design Support\AutoCAD_Support Folder\Plotters\PMP Files.
Which is invalid
Message 11 of 12
ronjonp
This works for me..
(strcat
  "\\OneDrive - Asda Stores Limited\\02_Model and Design Support\\AutoCAD_Support Folder\\Plotters\\PMP Files"
Message 12 of 12
ian
thanks do much for the support, I got there in the end
