No fuction definition VLR-REACTORS
dkerns
dkerns
For some reason my AutoCAD randomly just stops running lisp routines with  VLR-REACTORS
The only way I can fix it is by doing a software reinstall from the Windows control Panel
Once reinstalled they work again for a day a week or so then it happens again.
Any Idea what is breaking it?
kpblc2000
perhaps trouble based on your lisp reactors. Try (before loading vlr-functions) remove all reactors.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
dbroad
What happens after you use?
(vl-load-com)
Do you still have the problems?
If so, it is probably related to either a damaged install or profile where someone has deleted important support paths.
Architect, Registered NC, VA, SC, & GA.
dennis
I have had recently a plague of profile corruption.  The fix is to run the Reset to Default and then rebuild the Profile.  What is causing it is a mystery.  It has happened on both Win10 and Win7.
I'm also having the same problem. How do I turn off the reactors?
I also don't understand why after re-installing AutoCAD, it all works fine for about a week. Nothing noticeable has changed on my end and when I restart my computer and AutoCAD after a few days of normal usage, the error shows up.
