New Shortcuts dont work?
So after reading through some of the topics I went into the "acadlt.pgp" file and started editing my keyboard shortcuts.
My first was explode, which i changed to a simple "x" on the keyboard, which worked fine.
My next was offset, which I changed to "FF" on the keyboard, but autocad says "unknown command."
There is also no other command with that shortcut.
Why is it not working?
Make sure you REINIT your pgp file. Also add your custom commands on to the
end of the pgp. It loads those last even if a matching alias loads first
yours will be the one called up.
Erik
wrote in message news:5696578@discussion.autodesk.com...
worked fine.
Thank you!
That worked perfectly!
