NEW ERROR
NEW ERROR
rolisonfelipe
NEW ERROR
rolisonfelipe
Comando: PP
SELECIONE A LINHA INTERNA DA PAREDE:selecione a linha externa da parede:ERRO : bad DXF group:
(-3 ("STANDARD" (1000 . "P14") (1000 . "240X220") (1000 . "CORRER 04 FOLHAS") (1000)))Não é possível invocar (comando)
de *error* sem chamada prévia para (*push-error-using-command*).
Recomenda-se converter chamadas (comando) em (comandos-s).
pbejse
@rolisonfelipe wrote:
Comando: PP
I'm guessing its a company custom program in which case  there's little chance you can post the code here for debugging. in any rate, you can heed the warning and convert all (command) calls to (command-s) and see how it goes.
