need to store 2 node point of 1 bock in 2 different variable
Message 1 of 13
I have a 3D rectangular block. It is having 2 node points. I want to store coordinates of each node point in different variable say a and b.
Kishan
Replies (12)
Message 2 of 13
devitg
Hi @Anonymous  so simple
(setq osmode (getvar 'osmode))
(setvar 'osmode 😎 ; to snap at the node
(setq node-1 (Getpoint "\n pick at node-1" ))
(setq node-2 (getpoint node-1 "\n Pick at node-2 "))
(setvar 'osmode osmode)
Message 3 of 13
devitg
thais line should be
(setvar 'osmode ( 1+ 7   ))   ; to snap at the node
if not it show the smiley face
Message 4 of 13
pbejse
Are the 2 node points randomly located per 3D rectangular block?
Message 5 of 13
Kent1Cooper
To which I would add:
Is the idea that the User selects a Block insertion, anywhere on it [not necessarily at one of the Points], and the code finds where the two Points are, based on the Block definition?
What kinds of variabilities are to be expected?  Are the Blocks inserted at different rotation angles, and/or with different scale factors?  In different Coordinate Systems?
Kent Cooper, AIA
Message 6 of 13
Actually I was looking for a program like below,
I have a 3d rectangular block created by wblock command, the block has two node points A and B, And I need to store the coordinates of this node points in two different variable. WHEN I SELECT THIS BLOCK THESE NODE POINTS WILL AUTOMATICALLY GET STORE IN 2 DIFFERENT VARIABLES LETS SAY node-1 and node-2.
Thank you in Advance,
KISHAN
Message 7 of 13
(setvar 'osmode  ; to snap at the node
Thank you So much @devitg
Message 8 of 13
devitg
@Anonymous , a BLOCK is an ACAD entity, yours is, at least,  a CUBE as per geometry,   or a BOX  as per ACAD
such entity has not NODES it have m ENDPOINTS, MIDPOINTS, INTERSECTION
(setvar 'osmode (+ 1  32))  ; to snap  END, or to INTERSECTION
Message 9 of 13
devitg
a best way
(defun c:corners ()
(DEFUN GET-CORNERS  (/
                     CORNER-1
                     CORNER-2
                     OSMODE
  (SETQ OSMODE (GETVAR 'OSMODE))
  (SETVAR 'OSMODE (+ 1 32)) ; to snap to END, or to INTERSECTION
  (SETQ CORNER-1 (GETPOINT "\n pick at corner-1"))
  (SETQ CORNER-2 (GETPOINT CORNER-1 "\n Pick at CORNER-2 "))
  (SETVAR 'OSMODE OSMODE)
  (LIST CORNER-2 CORNER-1)
(setq corner-list (GET-CORNERS))
Message 10 of 13
Thank you for reply @devitg.
But I have one more question, let me share my drawing and let you know.
Message 11 of 13
Sea-Haven
Perhaps
(setq obj (vlax-ename->vla-object (car (entsel "pick object "))))
(vla-GetBoundingBox obj 'minpoint 'maxpoint)
(setq pointmin (vlax-safearray->list minpoint))
(setq pointmax (vlax-safearray->list maxpoint))
Message 12 of 13
Hello @Sea-Haven ,
I have tried the Code which you have shared but I need program for coordinates of the points shown in red circle which can be stored in two variables. but I dont want to prompt user two time to select two points instead of this can we prompt one time to pick object same as given in your code.
Thanks in Advance,
Kishan
Message 13 of 13
hak_vz
Picking two points is the best option that assures correct result. Two points on the edge can  be calculated from the method presented by @Sea-Haven  (box diagonal that don't always connect box edges i.e. it connects points on diagonal of a bounding box), but it don't give exact result in all cases.
Miljenko Hatlak
