Need the experts help on text export lisp
Message 1 of 9
Dear All,
I have a lisp program which exporting text to excel but its selection is one by one ,
can you please make this selection multiple in once ,  and when i click or select any text, can it change the color to remind its already selected ??
here is the lisp file.
thank you all
i am learning a lot from you all .
Replies (8)
Message 2 of 9
dbhunia
Try the attached lisp.......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 9
Thank you so much @dbhunia  !
for your help & quick reply !
its working and really good !
thanks a lot again @dbhunia
This lisp worked for all Quantity surveyor who is updating measurements sheets and tracking sheet from cad to excel and always searching this type Lisp to save time and easy to work,.
Message 4 of 9
dbhunia
Glad to help you:)
Debashis Bhunia
Message 5 of 9
@dbhunia  Sir , can you do some more help and favor ,
actually its not working same like before , i means i am calculation the pipe line , its like MH-1 to MH- 2 then length and after that MH-2 to MH-3 and then length , but when i click for MH-2 its not copying in text its coming only MH-3 and the length because MH-2 already selected but i wants to select again and again from to and length ,
and can you please make it export to direct in excel , in 3 columns text i means
i) MH-1 , ii) MH-2 , iii) length.
and then next selection and same on going.
thanks in advance !
Message 6 of 9
dbhunia
you please post sample files explaining what is your need....
I am on the way to home....... give me some time....
Debashis Bhunia
Message 7 of 9
dbhunia
Try this one.........
Debashis Bhunia
Message 8 of 9
THANKS again @dbhunia Sir,
its working also but !
actually i wants to select 1 item twice so when i am selecting same item again its not copying text and coming only the next one not the mid one
i attached the example of drawing screenshot,
where is from FCB/2/4/5/4 (CL, FGL , IL ) to CI/24/5/5 (CL, FGL , IL ) length is 33.14 and dia is 300mm (these are 4 items)  but when i am selecting from CI/24/5/5 (CL, FGL , IL ) to FI/24/5/6 (CL, FGL , IL ) length is 29.71 and dia is 300mm
then its not copying mid item CI/24/5/5 cause i am copying continuous and see the Swd-manhole result attached below,
and also this is copying from botim to top not from top to botim , can you please make this easeir .
i beleive you can do this and waiting for your kind help and favor.
thanks,
Tauseef Ahmad
i need in 4 columns
Message 9 of 9
dbhunia
But I have no problem....... See the attachment.......
Better you post some Actual Drawing Sample.......
Debashis Bhunia
