Need some help with CLAYER not being restored
king
king
(defun c:DC ( / curlay)
  (setq curlay (getvar "CLAYER"))
  (command
    "_.layer" "_set" "S - DETAIL CUT" ""
    "_.insert" "Detail Cut" "_scale" 36
    "_.layer" "_set" curlay ""
(Princ)
After the block is inserted on the proper layer per the code, the layer is not being reset properly to the previous current layer.
Any help would be appreciated, I'm still learning lisp
Kent1Cooper
You haven't completed the Insert command, within the routine and before the Layer resetting.  It can't go into the second Layer command when the Insert command is still running.
One way would be to add some pauses for insertion point and rotation, inside the routine, instead of letting the routine end and leave you to those inputs:
"_.insert" "Detail Cut" "_scale" 36 pause pause
Kent Cooper, AIA
king
Adding Pauses for my inputs worked, thanks for the clarification.
