At my workplace we have custom toolbars and buttons to insert blocks and upon insertion I pick a point and then it has me rotate them. Basically I copied one of these buttons and changed the macro to the new layer and block name
Example
Old:
^C^C-LAYER;SET;hvMb11-6;;-INSERT;HVMB11-6;\;;
New:
^C^C-LAYER;SET;Column_lock;;-INSERT;COLUMN_LOCK;\;;
What I don't understand is why the the block even asks for me to rotate as I don't see it in the macro. YES I AM A INEXPERIENCED with macros.
I would like to be able to insert the block,pick the rotation and then possibly move (slide) the block along the axis of the new angle if possible.
This is my first time using screencast so hopefully it will demonstrate what I am trying to get across. In the first part of the video I insert the block with the rotation option and the second part is the one I am trying to create.
