Need lisp
Need lisp
jowie6XC4P
Message 1 of 9
Need lisp
jowie6XC4P
Good day, heres the situation...
I have a drawing in which the limits is set to 0,0 420,297 equivalent to scale 1 of A3 size
now if want to rescale it into 2, limits shoud be changed 0,0 840,594
is there any lisp that youll only need to input the scale factor and changed the limits accordingly depending on the scale given
Replies (8)
Message 2 of 9
cadffm
why are you using limiten feature 🤔
and why are you need lispcode for this change 🤔
For users who can not use lisp or don't need lisp, you can do it by a simple menu macro
'_.LIMMAX;$M=$(*,2,$(index,0,$(getvar,LIMMAX))),$M=$(*,2,$(index,1,$(getvar,LIMMAX)));_.REGEN
Sebastian
Message 3 of 9
jowie6XC4P
is this macro for scale 2? what iwant is it will prompt what scale to be used and it will multiply to 420,297
Message 4 of 9
cadffm
@jowie6XC4P  schrieb:
is this macro for scale 2? Yes
Okay
multiply to 420,297 or multiplay to the current limmax?
Sample for limmin=0,0 limmax=420,297*user defined multiplier
^C^C^C_.USERI1;\_.LIMMIN;0,0;_.LIMMAX;$M=$(*,$(getvar,USERI1),420),$M=$(*,$(getvar,USERI1),297);_.REGEN
( still like to know why you are using limiten and don't like to offer a lisp solution 😉 )
Sebastian
Message 5 of 9
jowie6XC4P
macro or lisp, whatever as long as it has same function 😁
by the way can you tweak it a bit so it will accept a decimal figure?
Message 6 of 9
Kent1Cooper
In simplest terms, if I understand correctly what you're trying to do:
(defun C:LA3 (/ sc); = Limits for A3 sheet size
  (setq sc (getreal "\nScale {1 in}: "))
  (setvar 'limmin '(0 0))
  (setvar 'limmax (mapcar '* '(420 297) (list sc sc)))
Kent Cooper, AIA
Message 7 of 9
cadffm
Just to have answered this requirement as well:
USERI1 is for Integer, as you can read in your help [F1]
For Reals you can use USERR1 instead USERI1 - [F1]
Sebastian
Message 8 of 9
jowie6XC4P
big thanks for all the help
Message 9 of 9
Sea-Haven
We have used a A1 title block for years, it is set up in a layout and has been drawn 1=1 ie 841x594, so if plotted at 1=1 gives a A1 sheet, but we want A3, dont change the title block just change the output plot scale 1=2 you then get A3. What can be more simple and thats why layouts were invented.
