Need lisp to Delete attributes
Message 1 of 16
Hi, befor you say "look and you will find some" i have some, but they dont work i dont know why cause im a absolute rookie in autocad lisps but yeah.
I will attach you a cad 2010 (I work on autocad mep 2018 or autocad 2018)  saved file with the block reference i need, cause i have much more and they should safe there attributes.
I hope its clear what i want and i hope you will help me ^^"
Replies (15)
Message 2 of 16
ВeekeeCZ
So you want to remove an attribute or its content?
If the first one, use pendean's routine HERE
If the latter, then use dlanor's HERE
Just tried both and both works.
Message 3 of 16
cadffm
Wenn du nur die Werte von gleichnamigen Attributen löschen möchtest und nicht die Attribute,
dann kannst du die Blockreferenzen wählen und den Wert in der Eigenschaftenpalette löschen.
Auch kannst du ATTOUT <in Excel bearbeiten> und ATTIN benutzen.
Was ich aber überhaupt nicht verstehe: Du hast doch schon einen anderen Thread eröffnet
und nach genau so einer individuellen Programmierung gefragt und hast diese bekommen,
warum also die erneute Frage und ein anderer Thread anstatt in dem bestehenden zu bleiben?
Your other thread
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-delete-attributes-and-lisp-t...
Command CBA
googletrans
If you only want to delete the values of attributes with the same name and not the attributes,
then you can select the block references and clear the value in the Properties palette.
Also you can edit ATTOUT <in Excel> and use ATTIN.
What I do not understand at all: You've already opened another thread
and asked for exactly such individual programming and got them
So why the repeat question and another thread instead of staying in the existing one?
Sebastian
Message 4 of 16
Let´s take this code what do i have to change that it works for my drawing. My biggest problem with this codes is that everything is is shortcutted and so im never sure what i can change and what i cant without i kill the complete code.
(vl-load-com)
;Clear Block Attributes : This is will clear all variable attributes in ALL selected blocks in modelspace (set textstring to "")
(defun c:CBA (/ *error* ss obj atts)
  (defun *error* ( msg )
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred.")))
    (princ)
  );_end_*error*_defun
  (prompt "\nSelect Attributed Blocks to Empty : ")             ;; If you want to automate remove this line
  (setq ss (ssget '((0 . "INSERT") (66 . 1) (410 . "Model"))))  ;; If you want to automate (EVERY BLOCK) change this line to (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1) (410 . "Model"))))
  (if ss
    (repeat (setq cnt (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt))))
            atts (vlax-invoke obj 'getattributes)
      );end_setq
      (mapcar '(lambda (x) (vla-put-textstring x "")) atts)
    );end_repeat
    (princ "\nNothing Selected/Found")
  );end_if
  (princ)
);end_defun
@cadffm  wie ich eben oben beschreibe komme ich mit den codes nicht zurecht und die person die mir bis dato geholfen hat ist jetzt eine woche nicht da, dazu kommt das ich in dem thread 2 fragen gestellt habe wovon eine sich erledigt hat.
Message 5 of 16
cadffm
>"Let´s take this code what do i have to change that it works for my drawing."
NOTHING! so long we are talking about attributeVALUEs only (like your sample. Left blockreference is like "before" and the right one is the "result" of CBA)
You start the CBA command and select your blockreferences, or in the other order,
and CBA delete all attributevalues from all attributes of selected blockreferences.
(if layer0 is unlocked, what should be EVER the case)
Sebastian
Message 6 of 16
ВeekeeCZ
So the code works. Good.
And you don't understand the code. The code is really very simple, there is nothing much to change without some knowledge.
So the question is
- what you don't understand
- what change would like to make
Message 7 of 16
okey than tell me why it doesnt i tryed it right now selected the block references loaded the CBA...nothing
loaded the CBA selected the blocks ...still nothing
unfortunly im not allowed to give you the complete drawing so you can test but yeah
Message 8 of 16
cadffm
NO
YOU HAVE to test CBA with the given BULB.dxf first
if it is working there we can talk about your complete drawing
after you tested it in MODEL tab and ALL Layers unlocked.
____
Sorry, but a "does not work" is the weakest description you can deliver
Normally error messages should appear [F2].
Sebastian
Message 9 of 16
cadffm
@Anonymous  schrieb:
 loaded the CBA...n
LOADED???
You have to LOAD the lisp and then you have to START the new command!
Befehl: CBA
Sebastian
Message 10 of 16
yeah might me a weak discription but thats the case
Just drag and dropped : Befehl: (LOAD "C:/Users/Aleks/Desktop/Skript Projekt/Lisps/Attdel - Kopie (2).lsp") C:CBA
Appload loaded: Befehl: APPLOAD
Attdel - Kopie (2).lsp erfolgreich geladen.
btw in the bulb not the complete drawing
there are no frozen disabled or locked layers and im in the model tab. I also restarted autocad just to make sure
Message 11 of 16
ВeekeeCZ
HERE  is some basic info on how to use LISP.
Message 12 of 16
cadffm
@cadffm  schrieb:
NO
Open your bulb.dxf
drag&drop your lsp file
and start
Befehl: CBA
Objekte wählen:
Let us know at what step you stucked, it sounds you are not starting the new command by type in CBA..
Sebastian
Message 13 of 16
okey i missed that step thats the reason why it didnt work: Befehl: CBA.
with the missed step it works in the complete drawing also ^^
can we automize it so far that the lisp is choosing the right blocks automaticly ?
i really apriciate your patience.
Message 14 of 16
cadffm
For non-dynamic blocks it is simple, for dynamic blocks you need another code.
What are "the right blocks"? Just the one "DECKENLEUCHTE_M" ? Just in Model-Tab?
A stupid variant of this code:
(defun c:CBA_DECKENLEUCHTE_M (/ *error* ss obj atts)
    (princ)
  (setq ss (ssget "_X" '((0 . "INSERT")(2 . "DECKENLEUCHTE_M") (66 . 1) (410 . "Model"))))  ;; If you want to automate (EVERY BLOCK) change this line to (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1) (410 . "Model"))))
  (if ss
      );end_setq
    );end_repeat
  );end_if
  (princ)
);end_defun
Sebastian
Message 15 of 16
yeah its just this one block and just in model space so your code works fine. thx.
can we make that CBA_DECKENLEUCHTE_M tipping automized to ? or is this a nacessary step i have to do ?
Message 16 of 16
cadffm
There are so many ways to reach the goal and I hate to give a solution if I know there is too little knowledge about the process.
One possibility would be to add a (C: CBA) at the end of the Lisp file.
Whenever the file is loads, the command is executed.
But you better build a button that does the loading and running separately,
or you always load the file and you just have to start the command.
You go the worst way to learn = in a hurry
That's why i am out here.
Sebastian
