Need lisp for extrim ousdie rectangle /xplode blocks / delete
alsawadi.re
Message 1 of 8
alsawadi.re
Hello friends.. Plz I I have city plot with alot of blocks / text / mtext / polylines / splines/ lines etc..
I just want small part from that big plot by creating a rectangle and delete all outside objects including the crossed texts to the boundary of the rectangle.. Thanks
Accepted solutions (3)
Replies (7)
Message 2 of 8
Sea-Haven
If you use the EXTRIM function it has a different command name when using it in a lisp, its ETRIM.
(if (null etrim) (load "extrim.lsp"))
(etrim obj pt1)
Another I use is Cookiecutter2_v1.0.lsp as name suggests.
Message 3 of 8
alsawadi.re
Thanks my friend.. Actually I am not used to write lisp routines.. If u can help me to write whole.. And thanks again
Message 4 of 8
3wood
 You can also try EXPLODEALL.
Message 5 of 8
Sea-Haven
Wblock is close just copies what you select. What is wrong with draw rectang and type EXTRIM all done.
Message 6 of 8
ВeekeeCZ
Try the Export Layout command if works for you.
The attached routine uses this command and matches a viewport size with the given rectangle.
It could fail on large drawings (as Layer Export does).
Message 7 of 8
alsawadi.re
That was perfect .. Thanks
Message 8 of 8
alsawadi.re
thanks it was powerfull tool
