Need help with finding overlapping lines with one polyline and selecting them
rahul_jainMY6RE
Message 1 of 11
rahul_jainMY6RE
can someone help in slecting the lines below my polyline. Basically, i have 1 polyline drawn exactly over several normal lines. now what do i want is that i select that polyline and with the help of lisp or command the lines which are directly below it gets selected. and my original polyline gets deleted. can anyone please help regarding this issue.
This is my initial drawing in which i need the shortest distance between 2 points and the path that it traverses
Now i used Spath for that and while it was more helpful than most. it drew a red polyline (as shown in pic below) from P1 to P2 which gave me distance.
Now what i want that instead of polyline the path that i have drawn (the path that is below the polyline and exactly coincides with it) get selected because in that i have given separate names to the lines and i need that data.
So can u guys cook something up for this
@vladimir_michl
@pendean
@Kent1Cooper
Replies (10)
Message 2 of 11
daniel_cadext
You can use the routine mentioned in your other thread, SPATH I think it was.
Anyway, get the vertexes from the generated polyline and use those in a fence selection set
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 11
rahul_jainMY6RE
Hi Daniel can u elaborate more on this, I am not much familiar with fence selectionset
Message 4 of 11
Sea-Haven
An example
(setq plent (entsel "\nPick pline "))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))
(setq co-ord (cons (last co-ord) co-ord)) ; close
(setq ss (ssget "F" co-ord '((0 . "*LINE"))))
Message 5 of 11
rahul_jainMY6RE
Can anyone actually write a lisp for me for this issue. because i've failing miserably at this.
Message 6 of 11
komondormrex
check this out
(defun c:pick_under (/ target_pline target_pline_vertices target_pline_lines under_line_sset)
	(setq target_pline (car (entsel "\nPick target pline: "))
		  target_pline_vertices (mapcar 'cdr (vl-remove-if-not '(lambda (group) (= 10 (car group))) (entget target_pline)))
		  target_pline_lines (mapcar 'list target_pline_vertices (cdr target_pline_vertices))
		  under_line_sset (ssget "_f" target_pline_vertices '((0 . "line")))
	(foreach line (vl-remove-if 'listp (mapcar 'cadr (ssnamex under_line_sset)))
		(if (not (vl-some '(lambda (pline_line) (and (or (equal (car pline_line) (mapcar '+ '(0 0) (cdr (assoc 10 (entget line)))) 1e-1)
														 (equal (cadr pline_line) (mapcar '+ '(0 0) (cdr (assoc 10 (entget line)))) 1e-1)
													 (or (equal (car pline_line) (mapcar '+ '(0 0) (cdr (assoc 11 (entget line)))) 1e-1)
														 (equal (cadr pline_line) (mapcar '+ '(0 0) (cdr (assoc 11 (entget line)))) 1e-1)
						   target_pline_lines
			(ssdel line under_line_sset)
	(entdel target_pline)
	(sssetfirst nil under_line_sset)
	(print)
updated
Message 7 of 11
rahul_jainMY6RE
Thanks bro u saved me
Message 8 of 11
rahul_jainMY6RE
hi komondormrex can you check this formula again it isn't working on some cases. like if i change P1 and P2 to other points.
then the lines it is selecting are not complete
can you please check where the problem is arising.
Message 9 of 11
komondormrex
hi,
check update with fuzz added.
Message 10 of 11
rahul_jainMY6RE
Hi can you please tell me what is fuzz factor. I'm not sure what it is
Message 11 of 11
komondormrex
when comparing two points the fuzz is a distance within which points are supposed to be equal.
