Need help with access to property override of dimension in LISP
Hi All,
I've encountered a drawing file that has an overridden dimension property that I am trying to access problematically. When I select dimension object you can see in Properties that the Text Style is set to "Carducci-nrw" but that is not the style that is defined in the Dim Style in "DIM 48" as you can see in the second screen shot. How can I access this override and change the text style to something else?
James
