NEED HELP MODING THIS LISP
nikm42Q9N
nikm42Q9N
Hello ACAD gurus,
What I need is to use the EATTXT command but to skip all the menus ( saving files, selecting the block, selecting pcs, re ordering the columns and saving again) and I need to just get to the table to insert into the drawing. So in short I highlight all my tags and it pops out a table with no fuss
I have found this ATTCOUNT LSP ,my apologies to the author but I forgot where I got it. and I think it will do the job it just has some issues
1. It seems to add up all the lengths of each pc and give me a total in the chart. I just need the length of the pc listed there
2. I need to add a quantity column to the chart
attached is a file and the LSP code
ВeekeeCZ
Try this one. Note that it's not a versatile solution anymore.
nikm42Q9N
you sir are a saint thanks so much its perfect . what do yo mean by not a veritable solution anymore?
ВeekeeCZ
The correct functionality is limited on you that specific block. Not to any block with attributes. For that reason, now the selection is limited on SCI_TAG blocks only.
