Need Help modify Grid lisp routine
cesarmorin11
Message 1 of 10
cesarmorin11
Some one could please modify the lisp to eliminate the perimeter lines marked by an X.
Replies (9)
Message 2 of 10
ВeekeeCZ
The author @Lee_Mac himself has been spotted active here lately. I'm sure that Lee will make this tweak for you when he finds a minute.
Message 3 of 10
Lee_Mac
This can be achieved with a relatively straightforward modification to the 4 repeat loops which construct the static & dynamic horizontal & vertical lines forming the grid.
Change lines 106-109 from:
                (repeat (1+ *cols*)
                    (grdraw pt (list (car pt) (+ (cadr pt) vd)) 1 1)
                    (setq pt (list (+ (car pt) hs) (cadr pt)))
To:
                (repeat (1- *cols*)
Change lines 111-114 from:
                (repeat (1+ *rows*)
                    (grdraw pt (list (+ (car pt) hd) (cadr pt)) 1 1)
                    (setq pt (list (car pt) (+ (cadr pt) vs)))
To:
                (repeat (1- *rows*)
Change lines 119-128 from:
                (repeat (1+ *cols*)
                    (entmakex
                        (list
                            (cons 0 "LINE")
                            (cons 10 (trans pt 1 0))
                            (cons 11 (trans (list (car pt) (+ (cadr pt) vd)) 1 0))
To:
                (repeat (1- *cols*)
                    (entmakex
                        (list
                            (cons 0 "LINE")
And finally, change lines 130-139 from:
                (repeat (1+ *rows*)
                    (entmakex
                        (list
                            (cons 0 "LINE")
                            (cons 11 (trans (list (+ (car pt) hd) (cadr pt)) 1 0))
To:
                (repeat (1- *rows*)
                    (entmakex
                        (list
                            (cons 0 "LINE")
Note that, in each modification, I am simply subtracting 2 from the number of iterations of the loops (corresponding to the 2 outermost horizontal & vertical lines), and re-ordering the expressions within the loop such that the point is offset before the first line is constructed.
Message 4 of 10
martin_leiter
Hello Mr. Lee,
could you show us how to replace the lines with construction lines?
Because I can't do it.
Please Mr. Lee
Message 5 of 10
Thank you!  this works.😊
Message 6 of 10
Lee_Mac
Certainly - in either the original code, or the modified code, change:
                            (cons 0 "LINE")
To:
                           '(000 . "XLINE")
                           '(100 . "AcDbEntity")
                           '(100 . "AcDbXline")
                            (cons 11 (trans (list 0 vd) 1 0))
And change:
                            (cons 0 "LINE")
To:
                           '(000 . "XLINE")
                            (cons 11 (trans (list hd 0) 1 0))
Message 7 of 10
Lee_Mac
Excellent! You're most welcome 🙂
Message 8 of 10
martin_leiter
Hello Mr. Lee,
thank you very much for the change. It works very well.
Unfortunately, it does not work in the BKS. The construction lines are there somewhere.
Thank you Mr. Lee!
Message 9 of 10
ВeekeeCZ
Just curious what bks means?
Message 10 of 10
martin_leiter
UCS
