Visual LISP, AutoLISP and General Customization
Need code to modify all dimstyles
9 REPLIES 9
Message 1 of 10
382 Views, 9 Replies
My architects want all the dimension styles to be a thin dimension line and
thick text.
I can modify my dimstyle to do that but what I need to do is to modify
either the
dimension text color or the dimension lines in every dimension in a drawing.
I'd like to update every dimstyle defined in a drawing.
How can I do that?
Dave
9 REPLIES 9
Message 2 of 10
Hi David,
I use code similar to that below to globally change the "dimscale" for all
dimstyles.
The sample below is modified to change the text color instead.
Hope it helps.
Gary
[Code]
;Globally change text color for all existing dimstyles.
(defun C:DCOL (/ cursty intnum tblmem stynme oldech)
(setq oldech (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq cursty (getvar "dimstyle"))
(setq intnum (getint "\nEnter new dimension text color: "))
(setvar "dimclrt" intnum)
(setq tblmem (tblnext "dimstyle" 1))
(while (/= nil tblmem)
(setq stynme (cdr (assoc 2 tblmem)))
(command "-dimstyle" "restore" stynme)
(command "-dimstyle" "save" stynme "yes")
(setq tblmem (tblnext "dimstyle"))
);end while
(command "dimstyle" "restore" cursty)
(setvar "cmdecho" oldech)
(princ "Dimension color set to ") (princ intnum) (princ " for all styles.")
(princ)
);end function DCOL
[/Code]
Message 3 of 10
thankx Gary that did the trick
Dave
"Gary McMaster" wrote in message
news:5160644@discussion.autodesk.com...
Hi David,
dimstyles.
Hope it helps.
Gary
[Code]
);end while
(princ)
);end function DCOL
[/Code]
Message 4 of 10
Hi Gary,
When using the [ code ] flags make sure all are lower case.
eg
[Code]
(defun active-document ()
(cond (*active-document*)   ; Return the cached object
   (t
    (setq *active-document* (vla-get-activedocument (acad-object)))
[/Code]
eg
[code]
   (t
[/code]
Message 5 of 10
Now that's wierd!!
I did a test and all seemed logical. Until I posted here!
The test:
http://discussion.autodesk.com/thread.jspa?threadID=470207
Cheers
Phill
Message 6 of 10
Use Arial.ttf for font - you get thick text and looks good.
Message 7 of 10
sorry I want .shx not TTF
Dave
"None" wrote in message
news:5161516@discussion.autodesk.com...
Message 8 of 10
Gary
Is there a way to make this code not try to modify external referenced
dimension styles
Unknown dimension style.
"Z-2700-1-AFP1|Aec-Arch-I-96": Invalid file name.
Unknown command "YES". Press F1 for help.
Invalid style name.
thankx
Dave
Hi David,
dimstyles.
Hope it helps.
Gary
[Code]
);end while
(princ)
);end function DCOL
[/Code]
Message 9 of 10
Hi David,
I don't do much with xrefs (or lisp), but it appears that the "|" (pipe
symbol) appears in the name of all xrefed dimstyles.
Below is a modified version that tests for the pipe symbol and skips any
style that contains it. Probably not the best way, but it seems to work.
I was hoping one of the lisp experts would chime in and show us a better way
to do this. Possibly without using "command" or having to set each style
current.
Gary
[code]
(if (= nil (wcmatch stynme "*|*"))
(progn
);progn
);if
);end while
(princ "Dimension text color set to ") (princ intnum) (princ " for all
styles.")
(princ)
);end function DCOL
[/code]
Message 10 of 10
Got it. Thanks for the heads up.
Gary
Forma Design Contest
