need code to change lineweights and colors of entities in selected blocks
Hello to all:
I need some LISP code to accomplish two simple tasks.  Every project I work on has blocks, and I need LISP code that will allow me to select any number of blocks, then change the lineweight and color of all the entities inside the blocks to ByLayer.
I have tried searching the forum, but I cannot find what I need, what I seem to keep running into is "do it for everything in the drawing" and that's not what I need; I have to be able to select any number of specific blocks for this operation.  Thanks in advance for any replies!
_gile
Did you try the SETBYLAYER command?
Gilles Chanteau
GileCAD
GitHub
duh.  I' d heard about that one, but didn't realize that worked inside a block.  Thanks!
