Need a lisp that can create point on the intersection of diagonal of quadilateral (polygon having 4 sides)
inaamazmi
inaamazmi
paullimapa
BenCads
To use this code, type diagonalintersection in the AutoCAD command line. You will be prompted to select a quadrilateral (a polyline with four vertices), and then a point will be created at the intersection of the diagonals of the quadrilateral.
